Question about Faberware FCP280 Coffee Maker
8-cup Farberware electric coffee maker
Coffee does not perk long enough and does not get hot. Are thermostats available for home installation? Hate to throw it away as it was a Christmas gift and not very old. Just bought a 4-C pot but it is too small. Are the thromostats interchangeable? Thank you for your help on this matter. the coffee is not hot
  • 1,031 Answers
.There is a thermostat that controls the electric flow underneath to the heater. that is the most likely culprit. but am not surewhere to get another one. but you can easily changed with a Screwdriver. It shouldn't be more than $8
Posted on Aug 25, 2008
    Sergeant:
  • 359 Answers
Most electronics have a 1 year warranty, if you could find out were it came from you could take it back and get store credit for it. I wish I could help you more, but on this sort of thing I can't imagine there is much you can do other than that.
Do you have an instruction manual that i can download for a 55 cup farberware coffee maker?
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee makers try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Apr 15, 2011 | Faberware 12-55 Cup Coffee Urn
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
May 22, 2009 | Faberware FCP280 Coffee Maker
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Won't perk properly
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Oct 21, 2008 | West Bend 13500 Coffee Maker
Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Jul 06, 2008 | Faberware FCP280 Coffee Maker
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Oct 09, 2007 | Faberware FCP280 Coffee Maker
Faberware FCP280 Coffee Maker Logo
246 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
