Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE 2 Dryer
Dryer is less than 2 years old. The Control Lock button started beeping constantly about a month ago. Unplugged the dryer for a few hours and re-tried. Worked fine until it started the same thing again. Tried to unplug again but now Control Lock is on and will not go off after holding button.
We've check all Breakers. When you switch off the Breaker and flip it back on, the Control Lock does go off and stays off for about 30 seconds, but the dryer will NOT turn on. Then the Control Lock light comes on.
PLEASE! Any suggestions? I absolutely refuse to pay Sears to fix this piece of junk after paying so much for the set not even 2 years ago. Not the first problem we've encountered...
  • roxydudette Aug 27, 2008
    Thank you so much. I will check. I had figured all I had was the 1 year warranty and had given up hope. Now I have a glimmer...
    Genius:
  • 1,028 Answers
Sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Posted on Aug 26, 2008
F1 code on model# 110.77042600
My amana touch pad started going wacko...beeping constantly....then a F1 message....i unplugged it over night....then it worked for about 2 more days with no problems..then the next day it acted up again...Then i unplugged it again( touch pad only) over night . It has now been 1 month and no problems with it....so maybe before you dish out $$$$...maybe this will work for you also
Jan 03, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
May 23, 2010 | Kenmore Elite HE4 Electric Dryer
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Kenmore oasis dryer cycle signal beeping constantly
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the unit first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
165 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
