Question about Olympus Camedia C-3030 Zoom Digital Camera
Batteries How long do the batteries last in the C-3030 Zoom?
    Master:
  • 852 Answers
You will be able to shoot approximately 300-400 frames with the LB-01 Lithium batteries, under normal use. Battery life widely varies depending on the type of battery, manufacturer, camera use conditions, etc.
Posted on Sep 01, 2005
SOURCE:
Can not download from Olympus 3030 to MAC BOOK PRO
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Dec 20, 2012 | Olympus Camedia C-3030 Zoom Digital Camera
Cant find the cd to install the software for my c-3030 digital camera. can you help
You can find the software for the Olympus Camedia C-3030 Zoom HERE.
But if you need only the software, you might want to have the newer and
also free Olympus Viewer 2 software.
Aug 12, 2011 | Olympus Camedia C-3030 Zoom Digital Camera
Need usb software for c 3030 for windows 7 asap !!!
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Oct 26, 2010 | Olympus Camedia C-3030 Zoom Digital Camera
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Metering systems
The C-3030 Zoom has two metering systems: the Digital ESP metering system and the Spot metering system. In the Digital ESP metering system, the center and periphery of the picture composition are separately measured to select the optimal exposure. In the spot metering system, only the center is measured. Therefore, a darker subject can be taken with proper exposure without being affected by backlight, etc.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Batteries
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Batteries
With the provided Olympus CR-V3 batteries, you will get approximately 300 images under normal use. Using the Olympus Ni-MH batteries, you can get approximately 120 images per charge, and with alkaline batteries you would get approximately 30 images.
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Olympus Camedia C-3030 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
