Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Kenmore Progressive 25614/25615 - VERY loud buzzing noise
My vacuum (which I LOVE) has suddenly started making a VERY loud buzzing noise when brush is engaged (works as usual - nearly silently - when I'm using it on the "bare floor" setting). I've taken the thing apart twice, removed any stray strings and other potential noise-making things that I've sucked up in the vacuum, yet the problem persists.
This vacuum was an open-box special at sears (display model) and worked great for a year before it started making this hellacious racket. I've checked the belt - that doesn't seem to be the problem. Unfortunately, I do not have an owner's manual - tried TWICE to order one from Sears, but twice they charged me $13.99 plus shipping to send me the manual for the little motorized hand attachment. Apparently this manual is in three parts (based on my internet research), and they can't manage to send me the part that I need. Wah.
Any help would be VERY appreciated. My vacuum still works OK, but sounds like a buzzsaw!!
  • 1 more comment
  • mbhubbell Sep 14, 2008
    I too had a quiet vacuum but now have the same loud buzzing noise when vacuuming carpets. I have replaced the belt, just to see if it would help, but noise continues.
  • Anonymous Nov 29, 2008
    My brush and hose are clean and I have a new belt but the loud buzz saw sound continues. Any other suggestions?
  • Anonymous Jan 01, 2009
    I have the same problem... I took the beater head out and noticed that there was hair and fibers stuck behind the bearings (you will see them when you taket the plastic end caps off). Cleaning them out helped, but I'm thinking that the bearings are on there way out.
  • 833 Answers
Sounds like you have something caught in the brush path.
Posted on Nov 29, 2008
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
Beater bar rotating but now making really loud almost buzzing sound???
It is probably a bad belt.That model uses a geared belt and you possibly have a few teeth missing on the belt.It could also be a bad brush or bad motor but less likley.Take the cover off of the power nozzle and inspect the belt.Disconnect it and look at it for missing teelh or a bad spot where they look different than the rest if this is the problem you can stop reading and just go buy a belt.Spin the brush by hand it should give very little resistance without a belt attached.If it spins freely then inspect the ends for a bad bearing.Check the plastic end caps for melting.If they look ok then try moving the brush back and forth slightly to see if the bearing has come apart.If the brush is spinning free and the ends are not showing any movement other than spinning around then inspect the area where the belt rides and make sure it is free of debris like hair and string.Finally plug in the machine with the power nozzle attached and the brush disconected and cover still off and listen to the motor in the power nozzle.If it still makes the noise it's the motor www.sewvac.com
Jan 28, 2011 | Kenmore 25512/ 25513 Progressive Canister...
We have the Kenmore progressive direct drive (bagless) and have had it for about 3 years. We have taken good care of it, and paid quite a bit for it hoping that it would last for a good long time. It has...
there has to be a clog or block somewhere - if the motor works, it should work did you try a wire coat hanger to go up in further where you cannot see?
Bets regards
Ck
Jan 15, 2011 | Kenmore Progressive Bagless Upright with...
Our kenmore progressive with direct drive makes real loud noise when using and i am sure we have the bag on the right way
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Sounds like something is 'stuck' -
unplug, then unwind the shoelace from the roller.
Jun 15, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Vacuum making loud noise (like hole in tube)
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Nov 13, 2008 | Kenmore Progressive Bagless Upright with...
I have a Dyson vacuum cleaner ...upright....all of a sudden my vacuum started making this awful sound...like a loud buzz...but only when I have it on carpet....when I have it on "floor" mode it's...
it may just be, that on carbet the brushes make noise that you dont hear on woodfloors.
If there is a hights adjustment, set it higher for shaggy carpet and lower for berber.
Mar 16, 2008 | Vacuums
Loud Noise
This sounds like something is caught in the brush roller. It is not uncommon for something like a pin, or nail or something of that nature to get caught in the roller chamber and when the roller spins, it will rub on the roller producing that sound. Sort of like putting a playing card in the spokes of your bike when you were a kid. Take the bottom plate off and remove the roller. Inspect the area around the roller for any foreign objects. While your there, check the belt for wear and tension and also check the roller bearings for any material that would interfere with it's smooth rotation. You should also check the hose intake for blockage.
Feb 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
650 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
