Question about Olympus Camedia C-3030 Zoom Digital Camera
Metering systems
Which metering systems are used with the C-3030 Zoom?
    Master:
  • 852 Answers
The C-3030 Zoom has two metering systems: the Digital ESP metering system and the Spot metering system. In the Digital ESP metering system, the center and periphery of the picture composition are separately measured to select the optimal exposure. In the spot metering system, only the center is measured. Therefore, a darker subject can be taken with proper exposure without being affected by backlight, etc.
Posted on Sep 01, 2005
Electronic accelerator controlled system. Is the air mass meter built into the throttle control housing. How does the system work.
Electronic or fly-by-wire throttle or accelerator system these days means there is no direct connection between the engine and throttle pedal.
The pedal is linked to a potentiometer by a short cable or linkage or it could even be a part of the pedal assembly. The engine ECU uses the potentiometer output to determine the pedal position and instructs a servo motor to open or close the throttle as required depending on inputs from other sensors.
The air mass metering unit is not part of the throttle, or at least I haven't seen one that is (so far). There are various methods of operation of the air mass metering unit but regardless of which type is used they are almost exclusively placed to measure the air entering the engine before it has been affected by the heat from the engine. That is usually in or near the air cleaner. Not all management systems have used an air mass metering unit and a few relied solely on a MAP sensor and other sensors.
The ambient air temperature sensor is often integrated into the air mass metering unit or placed close to it.
The throttle body or housing these days generally contains various sensors, motors or actuators and often also electronic circuitry to provide dedicated application correction for the air mass metering unit because the response or output of that unit is not linear.
I hope this helps.
Nov 02, 2015 | Cars & Trucks
Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
Nov 27, 2009 | Cameras
I have that same problem but i own nikon D60 what settings do
M (Manual).
You won't get autofocus, nor will you get any metering. It's completely manual.
Aug 28, 2009 | Canon Opteka 650-1300mm F8/16 Super...
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The ADI flash metering mode combines distance information from the auto focusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, and 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Conversion lens
A conversion lens should be attached using the conversion adapter CLA-1 (41mm-43mm, optional) and the step-up ring. However, the fish-eye conversion lens FCON-02 cannot be used
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Batteries
You will be able to shoot approximately 300-400 frames with the LB-01 Lithium batteries, under normal use. Battery life widely varies depending on the type of battery, manufacturer, camera use conditions, etc.
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus Camedia C-3030 Zoom Digital Camera Logo
56 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
