EUROVOX MAX POWER PROBLEM
THE POWER IS RUNNING THROUGH THE BOARD BUT THE FRONT PANNEL IS DEAD AND NO PICTURE IM JUST WONDERING HAS SOMETHING BLOWN CAN IT BE FIXED OR IS IT SCRAP
  • 1 more comment
  • SLYMAN087 Aug 26, 2008
    ITS NOT A PC ITS A EURO VOX MAX DECODER IT WAS WORKING PERFECT FOR ABOUT 3 MONTHS AND THE OTHER DAY IT JUST WENT DEAD THE POWER IS RUNNING THROUGH THE BOARD BESCAUSE I OPENED IT UP TO CHECK BUT THE FRONT PANNEL IS NOT LIT UP AND THERES NO PICTURE
  • Anonymous Nov 27, 2008
    no power
  • al_sapper Mar 07, 2009
  • 3,051 Answers
Is this a new board that has been installed and is there any beeps at all you may want to try this make sure that the power supply is unplugged then remove the power supply cable that goes to the motherboard and then press in thee power button hold it there for 15 secondsw to ensure that all of the esd is discharged and then plug in the power cord back into the board and plug in the power supply to the computer and try to start ok please tell me if anything happness ok i can help more if needed ok best regards mike
Posted on Aug 26, 2008
Vizio VT470M no picture, no sound, no backlight. Power supply board looks good all voltages appear correct (24V, 5V, and 3.7V) and no "bulged" capacitors . When I unplug unit for two hours, the...
Im having similar problem and with my limited knowledge of lcd tvs and the voltages ALL being good except the pwr on or sw on voltage from the main board to the power supply which tells it to switch everything on Im guessing that something is going wrong on the main board. In the condition where it freezes it (the power on V) which switches everything on i get varied voltages such as 2.5 or 3 or (the normal 5v) and then when nothing powers up (blank screen) i read 0v on pwr on voltage but all my other voltages are corect (24v to inverter, 12 v to main board, 5v, etc.) Im guessing from researching this is that there is in improper voltage somewhere in the main board circuit. I have been unable to find it so i may order another board and post back.
Jun 19, 2012 | Vizio VT470M 47 in. TV
R56wh78 im having a problem.. the tv started the 3d effect so i replaced the convergence board.. and fixed the problem for about 2 days (convergence is still good).. now im having a new problem.. the tv...
The Deflection Power board is the the most likeliest cause of the dead set issue, and that could have also caused the prior issue of convergence board since the deflection board supplies all base voltages for the convergence circuits
Aug 16, 2011 | RCA Televison & Video
No power, tried a new power cord, still no power
Ur tv have any power lite flashes on the front power LED lite on the screen pannel?Yes,than the power supply board have dead leakage parts capaacitors,they bulges up on it top or puff off on it tops.U know basic electronic,soldering equipments and know soldering?Replaced those dead leakages gas capacitors on the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | LG 50PG20 50 in. Plasma HDTV
Will not come on
the problem can be solve by opening the back cover of the television to check for blown fuses but if otherwise the power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Hope this helps...
Jun 03, 2010 | Philips Magnavox 42MF521D/37 Television
Top drawer dead bottom drawer funtions fine
1-Pull out the drawer.
2-At the bottom either side has a plastice pin , use a long nose ply to pull them off.
3-The front pannel can be seperated from the tube by put both hands on the side of the front pannel with a pulling out force
Jul 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Before i just buy a bulb i was wondering if it could be something else or is it just the bulb cause i can here the motor running
All I can tell yo is that there can be something else, as when the bulb AC power supply is faulty you get same symptoms as a blown bulb. The most common situation is that the bulb has blown and the bulb cannot be tested if not mounting into a working unit.
The lamp power board can be tested by a technician reading voltage out and testing components.
Apr 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Feb 04, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Sumsung hps5053 would not turn on
I fixed this model of TV. Symptom was NO POWER. Totally dead. Not even a blue LED up front. Here's what I had to do...
I found a blown thermistor on the power supply board. It's green and located near the 120vac mains input to the board. There is a component number written on the board near it (as with all components) and it begins with "TH" i believe. So it will be something like "TH101". It was very easy to identify that this part had gone bad on my power supply, as i was literally blown apart and debris had been scattered all about the area.
Before finding this faulty component, I had done some preliminary voltage testing from the power supply's outputs. I started with the 5 volt stand by signal feeding into the logic controller board. It was bouncing around from 1v-3v.
After replacing the faulty thermistor, there was a steady 5v signal on the standby circuit. However, the blue power button was still not illuminating. And there was absolutely no voltage going into the power button board (which is fed from the logic controller). So after attempting to replace a few dozen suspect high ESR SMD caps on the logic board (to no avail), I ordered a new one.
And then the TV came to life.
Works great now!
Feel free to ask for advice.
Chris Boise LCD sales@boiselcd.com www.boiselcd.com
Jan 27, 2009 | Samsung HP-S5053 Television
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
Mdb8750aws dishwasher dead, no front pannel lights, no functions
I just fixed my washer!!! had power to control board. romoved lower panels openned connection box ( one screw) cut and cleaned wires and reconnected to power line that runs to the plug. Did it twice and finally got a good connection started right up. WAS just about to order a new circuit board. SAVED MYSELF $100.00 !!!!!
Dec 05, 2007 | Maytag 24 in. MDB8750AWS Jetclean II...
Computers & Internet Logo
674 people viewed this question
David Payne
David Payne
