Question about Xerox DocuColor 12 Printer
Xerox docucolor 12 please power off and turn back on.
My docucolor is doing the same thing thats mentioned in the post. I turn it on, and it says system will be ready in 7 minutes, then, all of a sudden it goes, system fault,power off then turn back on. But it never counts down from the seven minutes, it just stays at seven minutes then says power off and turn back on...please help me if you can.
-Thanks
Kellie
  • 62 Answers
You have a heater problem. The machine times out if it doesn't see an increase in temperature within a set time. What code are you getting?
Posted on Nov 19, 2008
Docucolor 12 no power up
something could be shorting it out. Which ac pwb have you changed? If the same thing happens when coming out of power save (it wont come out) then its the low voltage power supply. a common one with these machines
Feb 24, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Power problem
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12
The 2045 has a toner and Dev collection as dev ages ist looses its ability to charge and discharge and is then deposited into what is called the toner waste container. It has a different name but serves the same purpouse. TO answer the Question on the no power somemore info is needed. When you turn on the DC12 can you hear the fans run? do your hear any other noises when you turn your unit on??
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 system fault turn off and turn on problem
tell about error code which is appear left bootom of screen
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
How do I reset the indictor on a Dell printer cartridge after refilling it? xerox docucolor 12 printer
If this is a monochrome laser toner cartride you may need to purchase a CRUM chip to replace the one on the toner cartridge. If you had your cartridge refurbished by a company who specializes in this and they did not reset the CRUM you do not need to use them in the future. There may be a way to cancel the add toner message in the service mode so I will keep checking and post an updated solution should I find any available information. Could you confirm that it is a Xerox Docucolor 12 printer made for Dell?
Jun 03, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor problem
The only thing I can tell you to do is turn off the machine. On the back of the finisher, unplug the finisher from the processor and power up the machine, it will reconfigure, plug and play like, and send the pages to the center tray.
Once you do that. Go into machine status and into faults. Print out a fault page and tell me the finisher/stapler code coming up so I can let you know exactly whats going on.
I hate that software puts a machine down for functions you do not 100 percent need.
Mar 18, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
137 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
