Do you own the wireless network? It is possible to connect to a wireless network without being online IF the wireless network is not connected to the internet. So first you must make sure that the wireless network you are connected to, is connected to the internet.
You need to turn on your wifi which maybe on the outside or on your keyboard, then go to bottom right of screen & left click on wireless connection then click on "connect to a network"
I think there might be lost in the packet sending. You said the PC is still connected to the network but not able to go online. Is there any other wireless computer which is able to go online wirelessly and working fine. If yes then try to uninstall and reinstall the adapter. If not then check the router wireless settings. Click Here for more info about networking.
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
