Question about GE A730 Digital Camera
Battery/Camera dies? Battery Problem: I bought this camera last Dec, Just two weeks ago I have noticed the battery dies after 2 pictures have been taken. I have replaced all different kinds of batteries including a 15min battery charger. What is the problem, I am so dissapointed.? Like ch007, I have a GE digital camera model A730 and I get a warning that the batteries are exhausted after just a few pictures in spite of having replaced the batteries with new and charged rechargeable batteries of good quality. The batter indicator shows that the batteries are not exhausted but the warning says they are and the camera shuts down. I got my camera as well as 2 others of the same model as gifts for family at the same time that ch007 did.
  • 797 Answers
Go to the menu and make sure you have the battery type set to the kind you are using.
Posted on Sep 27, 2008
  • Dave Lundmark
    Dave Lundmark Sep 27, 2008
    Here is a link to troubles which may be related to this camera:
    The updating of the internal software called firmware may be what will help in this case.
    Worth a try.
    Make sure, if you update the firmware to follow the directions exactly, other wise you could damage the camera to the point of no return and render it of no use.
I bought my camera a week ago and it worked fine til today. I turned it on and took one picture then I got a notice that said "for use with compatible battery only." I haven't used a...
Sounds like you have a defective camera. You might want to take the camera back to the place you got it and get a replacement. You can try removing and reseating the batteries to fix the problem.
Jul 17, 2011 | Sony DSC-W510 Digital Camera
Sony Cyber-shot DSC-H7 Battery Life is Only Hours Now
Can you verify that your charger accessory is working correctly?
Jan 06, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Power Zoom Lever Doesn't Work
Hello, please try to use the memory stick. If there is a message MS error, please look at this picture. Best regards, Arpi If you need more info please advice.
Jul 11, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
White lines appearing on display after picture is taken
I have the same problem, and upon looking into my problem, i recall reading that Sony had used crappy glue in which they attached the CCD to the inner guts of the camera, and when that deteriorates, which doesn't take very long, then your pictures will have lines through them.
I think i remember reading that Sony said they will replace all cameras within 2 years of their manufacture. Call Sony's troubleshooting and support and they may replace it for you.
Hope i helped solve your problem.
- Josh
Oct 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Kodak Z740 digital camera
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
mi camara se me callo y la pila parece q se malogro que hago
Apr 19, 2008 | GE A830 Digital Camera
well, i just chcked my camera, and you have the right could be the battery is just bad, though i don't know how to check this without trying it in another camera.
Oct 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Camera will not turn on
I think the heat did it. If you read the instruction book, it most likely has a page that says no excessive heat or cold. If you bought it a week ago, take it back to the dealer for warranty repair.
Jun 28, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
GE A730 Digital Camera Logo
282 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
