Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Tub in washer empties as fast as the water runs into tub
The water flows into the tub a nice rate but the tub empties just as fast as the water is going into the tub. The pressure valve does not look to be damaged, and we have replaced the timer switch.
  • susanhaslam Aug 28, 2008
    my husband pushed the hose too far down the standpipe...saved us at least $65.00. Thanks
    Genius:
  • 1,028 Answers
Ck height of drain needs to be at least 30-36 inches from floor also be sure drain hose is only 6-8 inches into standpipe be sure there is a small air gap between drain hose and standpipe.. hose needs to fit loosely into standpipe or siphoning may occur
Posted on Aug 26, 2008
Why is my washer saying low water pressure. How can I fix that without have someone come out to repair it
It depends on the cause of the water pressure issue. I'd first check your incoming water to the washer. Turn off the inlet shut-off valves and disconnect the hoses. Check the hose filters and the inlet valve filters. Remove any debris. Next put a large bucket under the shut-off valves and open them fully for a minute. Check how much water flows into the bucket. If very little water was in your bucket, you'll need to check where the restriction is in your water lines. (The water pressure needs to be sufficient to fill the washer in about 8 minutes. Depending on your home, you may need a professional to check the water at your water connection to the city or at your well pump.) Empty the bucket. Replace your inlet hoses at the valve side and repeat the test. If you are getting low water flow with the hoses in place, replace the hoses. Some hoses have a "anti-flood" feature which restricts the hose if there is a problem. (I've seen the hot water flow rate to the washer significantly decrease due to the hose blocking the flow. The cold water hose was replaced at the same time to avoid it failing in a short time.)
Next check that the drain hose isn't below the level of the water in the washer. This can cause siphoning and empties the washer as fast as it fills.
If the water pressure is still low after testing these items, the problem could be the inlet valves on the washer or the air pressure at sensor that detects the water flow. On some washers, you may be able to remove the debris in the air tube. However, if there is a pinhole, that part will need to be replaced.
I hope this helps.
Oct 05, 2014 | Samsung WF328AA Front Load Washer
What is LF message
LF means a long fill was detected. This means that the washer sensor did not sense enough water coming into the unit in the first 8 minutes after starting the wash cycle.
There are several things that you can check. First, make sure that the incoming water pressure is good. You can try replacing the intake hoses and checking the filters on both sides (inside the washer and at the shut-off valves). (When you take the hoses off the shut-off valves, put a bucket under the outlets and check the flow rate.) Some intake hoses will seal themselves if they detect a leak. This will significantly reduce the water flow. If the filters are clogged, you get a similar restricted flow.
Next, check that the end of the drain hose is not positioned below the fill level of the washer. This will cause the water to be suctioned out of the tub as fast as it fills.
If the water is flowing well, the intake valves or the water pressure sensor (which detects the change in the weight of the tub) could be bad or have a wiring harness problem.
I hope this helps.
Aug 25, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Lgwm2032hw does not drain once tub gets full. how
The first thing to do is to empty the washer by allowing the water to flow out of the drain hose by gravity...If it won't flow you have a blockage and you'll have to check the pump filter which is accessed via the small door at floor level (or behind the kick plate) Unscrew the pump cover and check the filter..Water can and will flow out if you haven't emptied the washer. There may be a small hose which next to pump cover which allows controlled draining....Good luck....Nomess
May 13, 2010 | LG WM-2277HW Front Load Washer
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Whirlpool washer
    the Pressure switch is bad (also called Water level switch) there is a small hose from the tub that runs up to it ..The tub will need top be empty when this part is changed
    Mar 02, 2008 | Washing Machines
    Kenmore washer - water is emptying from tub but clothes are not spinning dry
    replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
    Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
    71 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
