Question about AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher
AEG Favourite Dishwasher will not lock
Hi, my AEG Favourite integrated dishwasher will not lock. It is levelled correctly and will function even though it is not closed. Can you help please?
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
SOURCE: Ontegrated dishwasher door fitting
wash your dishes by hand
Posted on Jul 05, 2007
SOURCE: Dishwasher fail on C3 (leak prevention system)
in German ... anyway a couple of pictures :)
Posted on Feb 18, 2008
SOURCE: AEG dishwasher 80850 code i30 reset
empty it, tip it on its back, mop up the spilt water, reload it and all should be ok. it is a recurring fault on our machine very irritating
Posted on Jul 30, 2008
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
AEG dishwasher integrated Model newly installed but when I lower the door to load it the dishwasher moves out from under counter and then wont close properly how do I solve this problem?
The built-in dishwashers are almost fixed by screws in top or by side. Carefully read the installation manual where it is explained in detail how to fix the dishwasher under the kitchen worktop. You also need to adjust the height by using the swivel legs that will additionally fix the dishwasher.
Jun 24, 2017 | AEG Dishwashers
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Door on my integrated AEG dishwasher keeps opening during operation
Hi Chasmolly
Remove the inner stainless door panel by taking out the self tapping screws around the edge this will expose the door lock mech at the top
You will notice a small white plastic spigot protruding out from the lock mech,grip it with a pair of pliers and rotate to adjust the door lock pre load
It should snap shut and squash up the seal,do not do it to tight so you rip the trip panel off trying to open it !
Good Luck
Jan 09, 2011 | AEG Dishwashers
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Hi, I have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Dec 21, 2009 | AEG 24 in. Favorit 60870M Free-standing...
Dishwasher failed to drain,have emptied m/c manually & it now will not start
The pump must be accessed, removing the hose from pump and checking from blockage.
Check the float sensor, and the pressure sensor, this devices are used to determine the water level, and if they are defective they may cause machine not draining.
If the machine does not start at all, check circuit breaker, check the fuse on power cord if cord is fused, and ensure the door lock is working.
If still no luck I suggest ringing AEG at the number listed on the owners manual.
Dec 13, 2009 | AEG Dishwashers
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Open Questions:
See all AEG 18 in. Favorit 54750Vi Slim-Line Built-in Questions
AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher Logo
42 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
