Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Motorola T5420 Transmit Problem
Had tried your solutions but the problem persisted.
Had new AA batteries in both talkies, set the interference eliminator code to 0 yet I'm still unable to transmit / receive any message.
Need help.
Thanks.
  • 1 more comment
  • Xephonx Aug 27, 2008
    The walkies are in good condition, same condition as last used, been sitting in my cupboard in the original packaging.
    The last time I used the walkies are in a dry and sunny day.
    Sound works normal, still gets the startup beep, moni static sound, PTT pressed & release beep.
    Everything works fine except it's unable to transmit.
    Will try out the rechargeable battery pack that came with it and see if it transmits.
    Thanks.
  • Xephonx Aug 29, 2008
    Ok, I managed to get the walkies to transmit and receive. But there is this one problem.
    I'm only able to transmit and receive between walkie A and walkie B only but not to walkie C and walkie D.
    Walkie C is only able to transmit to walkie D only and receive between these two. Why am I unable to transmit and receive between walkie A and walkie C?
    The problem I had post earlier on is this problem. Batteries aren't a problem as I switched AA and rechargeables here and there.
    Thanks.
  • eradiostore
    eradiostore May 11, 2010
    Other than being a programming issue, is it possible you had gotten the radios damp or wet during their last use? If so, you could have a corrosion issue.
    If your Frequency and Code are set to match one another; you have fresh batteries; and you have checked your VOX setting, at this point you have checked everything which can be done from a programming standpoint.
    Do you get any sound of the of the speakers at all?
    It still is unlikely for 4 radios to fail at the same time. It is a mystery. I'll be pondering other possible solutions.
  • Motorola Master
  • 1,654 Answers
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Posted on Aug 27, 2008
  • eradiostore
    eradiostore Aug 29, 2008
    If we go from the standpoint that the radios are in working order and free from defect, the interference eliminator code or the Qt filter would be the most obvious issues to double check.
    If you cannot see a difference on these two issues, you might have a second set of eyes look at them.
    I am glad to hear you went from 4 radios not working together to only two with questions. I do suggest after you get this programming problem resolved, you might want to turn on the programming lock. =)
One of my radios wont transmit
Check your CODE (aka private line, PL, quiet call, interference eliminator) setting. You may have the two radios set differently. One radio is possible set to open squelch (no CODE) and the other one has a CODE selected. This is an extra filter of sorts which blocks out other users who are on your frequency, so you don't have to hear them. Only radios set identically can communicate.
Two other possibilities include bad or poorly charged battery or a problem with one radio.
Best regards.
Jul 21, 2015 | Radio Communications
New ms 350 one radio will not work all same settings.
Here are a few things to try:
1) Trade battery packs with a known good radio and see if the problem is solved. If so, you have a bad or poorly charged battery.
2) Take your radio back to a very basic programming with all special features turned off (or set to zero), and the interference eliminator code turned off (zero). See if the units will work together. If not, one radio is bad or defective. If less than a year old, you should use the toll-free number for Motorola/Giant Intl provided in your user guide to contatct them and likely get a replacement radio.
Best regards.
Sep 25, 2013 | Motorola Walkie Talkie 2-Way Radio
I have a walkie talkie i can talk to the reciever and hear it but i cant talk back from the reciever
Check your private line code (aka tone code or interference eliminator code). One of your radios possibly has it set differently than the other.
Sep 24, 2011 | Radio Communications
What code to use for motorola sport 7 walkie talkies
Sport 7 radios were sold before the "interference eliminator code" was a standard option. In most cases setting your other radios to code zero would match the Sport 7 radio.
If this does not solve your problem please post another question and list the model of your other radio you are trying to use with the Sport 7.
Best regards.
Nov 17, 2009 | Motorola Talkabout SX900R Two Way Radio
I have a sx600r motorla walkie talkie and mess up the frequency
You will need to set the menu options to match one another. Here is a copy of the user manual to assist you. The frequency, interference code eliminator, and the Qt filter must match one another.
http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf You'll find what you need under the heading of menu options on page one, and it continues onto page 2.
Aug 23, 2009 | Motorola Walkie Talkies 2-Way Radio
Cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
Aug 07, 2009 | Motorola TalkAbout T5000 2-Way Radio
We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Feb 24, 2009 | Motorola T8500 Two Way Radio
T5420 unable to transmit or receive. Please help!
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
Unsilence
Hello gc0273,
Make sure that both radios are using the same Interference Eliminator Code. The situation you describe sounds like one radio has a Interfernce Eliminator Code activated and the other radio does not.
To access the Interfence Eliminator Code setting on this radio press and hold the MENU button until the code starts to flash, then use the + or - keys to adjust the setting and press the PTT to save it.
Best Regards
Agent Ken
Go Ahead. Use Us.
Mar 02, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
546 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
