Question about Toshiba 32A33 32" TV
Tv will not turn on
Redlight flashes of and on
  • 2,071 Answers
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Posted on Aug 25, 2008
I have a toshiba model 32A14 when i plub it in, and try to turn it on it does nothing.
Posted on Aug 29, 2008
Sony Bravia Tv shutting off and redlight flashing. How can I fix this?
Poor information...what pattern of flashing ie:4 flash pause 4 flash pause etc. There are many Bravia models out .
Feb 28, 2017 | Sony BRAVIA Televison & Video
Lcd tv redlight flashing tv wont turn on
These blinks (flashes) are fault inidication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts.
Dec 24, 2013 | Televison & Video
Ngv510 red light blinking
hello i was wondering if anybody can help me out here,recently my att unverse dsl nvg510 modem redlight (wifi setup ) is flashing red and sometimes flashing green. my internet is running good, all the device that connects to wifi is good also. and also i unplug the power for few minutes and plug it back in and still that redlight keeps on flashing. nobody can answer my question. thank you
Jul 29, 2012 | Arris Nvg510 At&t U-verse Modem Gateway...
Shut off flashing redlight
Take the tv aparts.Power supply board have these dying leakage gases parts call capacitors.The power supply board,that the board where the power a/c cord plug into it.U know basic's electronic,have tools and know basic soldering?Searches the power supply board,and it supporting boards,look for those dying parts call capacitors it have gases leakages,alway bulges up on tops or puff up on it tops.Replaced these dying to be dead capacitors,the tv power will be stable in ur tv again and work.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Jul 13, 2010 | Philips 42PF7220A 42 in. Plasma Television
POWER UP redlight flash and then die
power supply probably bad ,needs a test bench and tech to confirm
Nov 25, 2009 | Toshiba 27D46 27" TV
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
1 or 3 redlight flashing
Aug 03, 2008 | Microsoft Xbox 360 Console
Flashing redlight
the problem could be what's called a cold solder. Find someone with experience in finding and repairing a cold solder on the tv board.A couple hundred bucks to repair, maybe.
Jan 19, 2008 | Philips 34PW9819 34" TV
Sony Wega 36fs120 tv
possible bad connect microprocessor circuit. recommend Sony authorized tech assist.
Sep 26, 2007 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Toshiba 32A33 32" TV Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
