Question about Boating
Quicksilver throttle assembly
Tilt and trim button will not work on the up position, down works great, jumped at solenoid and up position works. what could be wrong could it be the switch
  • 21 Answers
Yes the switch could be bad. Is it on the throttle? Does it work on the engine? I have had my switch go out twice on my mercury.
Posted on Dec 01, 2008
  • Ernie Petross
    Ernie Petross Dec 01, 2008
    yes the switch could be bad. Is it on the throttle? Does it work on the engine? I have had my switch go out twice on my mercury.
Trim relay mounted in the moter housing, 2 small black boxs one for up one for down about $20.
Posted on Sep 14, 2009
When tilting the motor down it jumps and bangs until it gets to the trim pistons, what is causing this?
Power Tilt and Trim Maintenance Makes a Difference ...
yamahaoutboards.com/.../power-tilt-and-trim-maintenance-makes-differe...
Tilt and trim adjust the angle of the motor and thus the running surface of the boat, ...the grip on the water, the ability to jump on plane and many other operations ... be around the base of the ram, or drip down around the power tilt and trim motor. ...Sometimes you can bang on the power tilt and trim motor with the head of a ...
Jan 10, 2016 | Boating
Tilt and trim wont trim up taking off works fine running down the lake
Check trm/tilt release screw,does trim motor run but motor doesn't lift,if trim motor doesn't run then it's probably trim solenoid/relay
Oct 09, 2014 | Boating
Why will trim & tilt on my outboard work sometimes and sometimes it will not?
I would look for a corroded ground wire or a connection that has a corroded connection. Clean all ground and hot lead connections, then seal them from moisture.
Sep 14, 2014 | Cars & Trucks
Tilt trim
Many if not most trim systems have a solenoid much like an old ford that is bolted on the fender well near the battery. Of course make sure all cables and other wires are CLEAN. Often they can appear clean but take one off and use a wire brush. More than likely If all cable ends are clean including the wire inside the cable , the solenoid is faulty. Hope its not the electric motor worn out causing too much drag. Some can be rebuilt.
Jun 14, 2013 | Boating
How does a quicksilver throttle trailer button work
The intended function is:
Trim adjustment is limited by a sensor on the lower unit. This control stops when pushing "bow up" or similar words, limited by the sensor on lower unit.
The trailer button overrides this limit, allowing the lower unit to raise beyond normal running positions, all the way to the fully up (trailer) position.
May 05, 2012 | Mercury Boating
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
I have a 1994 150 hp Yamaha outboard motor with tilt-trim. My motor is stuck in the up tilt position and will not tilt down. It is working when I go up, but not down. I have talked to a used parts dealer...
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Jul 14, 2009 | Boating
Power trim on 60 hp yamaha quit working
find the solenoid for the trim it will be a the engine or on the trim motor it self get a test lite and find the power wire on the trim motor and with someone pushing the trim button test the hot on the motor if there is no power it is the solenoid if there is power u my have a brush stuck in the trim motor itself but 99% of the time it is the solenoid u can tap the trim motor and see if that gets a result but dont hit hard
May 08, 2009 | Yamaha 12V Air Pump
Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Mar 28, 2009 | Boating
Boating Logo
2,001 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
