Question about Olympus Camedia C-3030 Zoom Digital Camera
Extension Flash connector terminal
What is the purpose of the Extension Flash connector terminal?
    Master:
  • 852 Answers
You would use the Extension Flash connector terminal along with the optional flash bracket "FL-BK01" and bracket cable "FL-CB01" so that you can use the Olympus FL-40 dedicated flash. With the use of bracket cable "FL-CB04", you can use another brand extension flash.
Posted on Sep 01, 2005
Where is the obd2 connector location on holden ra rodeo v6
Connect white (test lead) and black (ground lead) wires that are branched from harness approximately eight inches from ECM. After leads are grounded, the "Check Engine" light will flash the diagnostic trouble codes. The DTC's are indicated by the flashing CEL.
FLASH, FLASH, pause, FLASH, FLASH, FLASH = Code 23.
If only one diagnostic trouble code is stored, the DTC will repeat continuously until test leads are disconnected. If more than one diagnostic trouble code is stored, each DTC will repeat three times, starting with the lowest, then proceed to the next DTC. After all DTC's have been displayed, the pattern will repeat.I-MARK 84-85
Connect male and female test leads taped into wire harness near ECM. After leads are connected, the "Check Engine" lamp will flash the trouble codes. The DTC's are indicated by the flashing CEL.
86-87 Impulse located near the ECM connector, is used to actuate the Engine Control Module (ECM) trouble code memory within the module. Two terminals (A and C) of this connector are used to activate the diagnostic trouble code system in the ECM. With the ignition switch turned On, engine Off, connect a jumper wire between terminals A and C. The "Check Engine" lamp will begin by flashing a DTC 12. DTC 12 = flash, pause, flash, flash. There will be a longer pause and a code 12 will repeat two more times. This code indicates the self-diagnostic system is operating. The cycle will then repeat until the engine is started or the ignition is switched Off. In most cases, DTC's will be checked with the engine running since no DTC's other than DTC 12 or 51 will be present without the engine running. Remove jumper wire from ALDL connector before starting engine. Reconnect jumper wire after engine is running.
Throttle Body Fuel Injection
The ECM test connection is located under the center console.
A built-in, self diagnostic system will identify problems in the throttle body fuel injection system. When a problem is detected, the diagnostic system will illuminate the "Check Engine" light.
When the engine is started, the Check Engine light should turn off.. If the light remains lit, the self diagnostic has detected a problem. To determine where the problem exists, ground the "Test" terminal of the connector with the ignition On, engine Off and watch the check engine light. Each DTC will flash three times (lowest to highest).
Aug 21, 2014 | Holden Rodeo Cars & Trucks
How do you read a computer on an 1986 toyota pickup
Jumper the TE1 terminal to the E1 terminal in the diagnostic connector with the ignition switch on and the check engine light will flash the codes. I think the diagnostic test connector is under the hood on the drivers side near the strut support and air filter box. It has a hinged plastic top about 3/4" x 1-1/2" in size. the terminal labels are inside the cap.
Feb 19, 2013 | 1986 Toyota Pickup 4WD
97 buick century has no data from OBD2 scanner.
The protocol is class 2 . Maybe your code reader is no good .
012 GM Class II Communications
Data Link Connector (DLC)
The data link connector (DLC) contains the following serial data links:
• Class II
• Entertainment and Comfort (E&C)
The DLC also provides a power source for the scan tool as follows:
• Unswitched voltage (B+) at DLC terminal 16 (circuit 1450)
• Ground at terminal 4 (circuit 1450) and terminal 5 (circuit 1550)
Class II Serial Data Link
The class II serial data link allows the following modules to communicate data with each other:
• Body control module (BCM)
• Electronic brake traction control module (EBTCM)
• Heater-A/C control (if equipped with RPO CJ2)
• Instrument panel cluster (IPC)
• Powertrain control module (PCM)
• Inflatable Restraint Sensing and Diagnostic Module (SDM).
The Class II serial data link allows a Scan Tool scan tool to communicate with the above modules for diagnostic and testing purposes. The Class II serial data link is located at the DLC connector terminal 2. Terminal 2 consists of the following circuits:
• Circuit 1036
• Circuit 1037
• Circuit 1128
• Circuit 1049
• Circuit 1122
• Circuit 1132
Entertainment and Comfort (E&C) Serial Data Link
The entertainment and comfort (E&C) serial data link allows a scan tool to communicate with the radio or the mobile telephone handset the remote CD player (if equipped). This communication is for diagnostic and testing purposes. The E&C serial data link is located at the DLC connector terminal 14, circuit 835.
PIN #9 goes to the air bag module .
Aug 04, 2017 | 1997 Buick Century
Where is the computer test plug in
ALDL connector located under the dash on the driver side. you can insert jumper wire from terminal B diagnostic test terminal to terminal A ground of ALDL connector.the service engine light will flash trouble codes if you dont have obd 1 scanner.you will need engine code manual to look up your codes.
Apr 15, 2011 | 1992 Buick Roadmaster
It is Vitara sidekick 1997 model. Water temp sensor is replaced, the fault code erased, when I start the engine and drive, every thing looks nice, but when I switch off the Ig key and start the engine next...
you can get codes with out scan tool, this is done by counting the engine light flashes, for example a long flash is the first didgt and then faster blinks would be the next number, for example long flash long flash long flash= 3 then fast flash ,fast flash, fast flash, fast flash =4 which would be code 34, to get the codes look in the engine compartment in front of the battery is the connector, you will need a small wire to jump two terminals, jump terminals with wire then turn key on and count flashes, i will give you a diagram to locate connector and it will show you which terminals to jump look at connetor closely to make sure you are jumping the correct terminals, you can turn the key off and on to restart the codes again,this may take you a few trys to get the hang of it but you can restart the codes by just turning the key off and back on, when your done just remove the jumper wire,also a diagram is enclosed to show you how the flashes go, hope this helps ,good luck.
Mar 05, 2011 | 1993 Suzuki Sidekick
What button sequence to I press on the vic to get the cpu codes for the check engine light?
Reading & Clearing Codes READING CODES (EXCEPT CADILLAC) Fig. 4: Example of a code 12 displayed on the check engine lamp 79222g25.gif
Since the inception of electronic engine management systems on General Motors vehicles, there has been a variety of connectors provided to the technician for retrieving Diagnostic Trouble Codes (DTC)s. Additionally, there have been a number of different names given to these connectors over the years; Assembly Line Communication Link (ALCL), Assembly Line Diagnostic Link (ALDL), Data Link Connector (DLC). Actually when the system was initially introduced to the 49 states in 1979, early 1980, there was no connector used at all. On these early vehicles there was a green spade terminal taped to the ECM harness and connected to the diagnostic enable line at the computer. When this terminal was grounded with the key ON, the system would flash any stored diagnostic trouble codes. The introduction of the ALOL was found to be a much more convenient way of retrieving fault codes. This connector was located underneath the instrument panel on most GM vehicles, however on some models it will not be found there. On early Corvettes the ALOL is located underneath the ashtray, it can be found in the glove compartment of some early FWD Oldsmobiles, and between the seats in the Pontiac Fiero. The connector was first introduced as a square connector with four terminals, then progressed to a flat five terminal connector, and finally to what is still used in 1993, a 12 terminal double row connector. To access stored Diagnostic Trouble Codes (DTC) from the square connector, turn the ignition ON and identify the diagnostic enable terminal (usually a white wire with a black tracer) and ground it. The flat five terminal connector is identified from left to right as A, B, C, D, and E. There is a space between terminal D and E which permits a spade to be inserted for the purposes of diagnostics when the ignition key is ON. On this connector terminal D is the diagnostic enable line, and E is a ground. The 12 terminal double row connector has been continually expanded through the years as vehicles acquired more on-board electronic systems such as Anti-lock Brakes. Despite this the terminals used for engine code retrieval have remained the same. The 12 terminal connector is identified from right-to-left on the top row A-F, and on the bottom row from left-to-right, G-L. To access engine codes turn the ignition ON and insert a jumper between terminals A and B. Terminal A is a ground, and terminal B is the diagnostic request line. Stored trouble codes can be read through the flashing of the Check Engine Light or on later vehicles the Service Engine Soon lamp. Trouble codes are identified by the timed flash of the indicator light. When diagnostics are first entered the light will flash once, pause; then two quick flashes. This reads as DTC 12 which indicates that the diagnostic system is working. This code will flash indefinitely if there are no stored trouble codes. If codes are stored in memory, Code 12 will flash three times before the next code appears. Codes are displayed in the next highest numerical sequence. For example, Code 13 would be displayed next if it was stored in memory and would read as follow: flash, pause, flash, flash, flash, long pause, repeat twice. This sequence will continue until all codes have been displayed, and then start all over again with Code 12. CLEARING CODES (EXCEPT CADILLAC) Except Riviera, Toronado and Trofeo: To clear any Diagnostic Trouble Codes (DTC's) from the PCM memory, either to determine if the malfunction will occur again or because repair has been completed, power feed must be disconnected for at least 30 seconds. Depending on how the vehicle is equipped, the system power feed can be disconnected at the positive battery terminal pigtail, the inline fuse holder that originates at the positive connection at the battery, or the ECM/PCM fuse in the fuse block. The negative battery terminal may be disconnected but other on-board memory data such as preset radio tuning will also be lost. To prevent system damage, the ignition switch must be in the OFF position when disconnecting or reconnecting power. When using a Diagnostic Computer such as Tech 1, or equivalent scan tool to read the diagnostic trouble codes, clearing the codes is done in the same manner. On some systems, OTC's may be cleared through the Tech 1, or equivalent scan tool. On Riviera, Toronado and Trofeo, clearing codes is part of the dashboard display menu or diagnostic routine. Because of the amount of electronic equipment on these vehicles, clearing codes by disconnecting the battery is not recommended. Riviera, Toronado and Trofeo (Non-CRT/DID Vehicles) — Using The On-Board Diagnostic Display System: First turn the ignition to theON position. On Riviera depress the OFF and TEMP buttons on the ECCP at the same time and hold until all display segments light. This is known as the Segment Check. On Toronado and Trofeo follow the same procedure, however, depress the OFF and WARMER buttons on the ECOP instead. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. For example, 'EC?' would be displayed on Riviera for EOM testing, while on Toronado and Trofeo the message 'ECM?' will appear. The message is more clear on these vehicles due to increased character space in the IPO display area.
  1. Depress the 'FAN UP' button on the ECCP until the message 'DATA EC?' appears on the display for Riviera, or 'ECM DATA?' is displayed on Toronado and Trofeo.
  2. Depress the 'FAN DOWN' button on the ECCP until the message 'CLR E CODE' appears on the display for Riviera, or 'ECM CLEAR CODES?' is displayed on Toronado and Trofeo.
  3. Depressing the 'FAN UP' button on the ECCP will result in the message 'E CODE CLR' or 'E NOT CLR' on Riviera, 'EOM CODES CLEAR' or 'ECM CODES NOT CLEAR' on Toronado and Trofeo. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset. Toronado and Trofeo (CRT/DID Equipped) — Using The On-Board Diagnostic Display System: First turn the ignition switch to theON position. Depress the 'OFF' hard key and 'WARM' soft key on the CRT/DID at the same time and hold until all display segments light. This is the 'Segment Check.' During diagnostic operation, all information will be displayed on the Driver Information Center (DIC) located in the Instrument Panel Cluster (IPC). Because of the limited space available single letter identifiers are often used for each of the major computer systems. These are: E for ECM, B for 6CM, I for IPC and R for SIR. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. This will be displayed as 'ECM?'.
  4. Depress the 'YES' soft key until the display reads 'ECM DATA?'.
  5. Depress the 'NO' soft key until the display reads 'ECM CLEAR CODES?'.
  6. Depressing the 'YES' soft key will result in either the message 'ECM CODES CLEAR' or 'ECM CODES NOT CLEAR' being displayed, indicating whether or not the codes were successfully cleared. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset.
Jul 10, 2010 | 1992 Oldsmobile Toronado
What are the omes and value of mass airflow sensor and amount of resistance?
Please don't forget to rate! Thanks!
Unplugging the sensor connector below the MAF sensor, for testing purposes
  1. Using a multimeter, check for voltage by backprobing the MAF sensor connector.
  2. With the key ON, and the engine OFF, verify that there is at least 10.5 volts between the VPWR and GND terminals of the MAF sensor connector. If voltage is not within specification, check power and ground circuits and repair as necessary.
  3. With the key ON, and the engine ON, verify that there is at least 4.5 volts between the SIG and GND terminals of the MAF sensor connector. If voltage is not within specification, check power and ground circuits and repair as necessary.
  4. With the key ON, and the engine ON, check voltage between GND and SIG RTN terminals. Voltage should be approximately 0.34–1.96 volts. If voltage is not within specification, the sensor may be faulty.
May 12, 2010 | 1997 Lincoln Town Car
What are the lower black and red terminals used for. i have the top terminals hooked up to my receiver. do you have a diagram that you can e-mail me. thanks j
The lower connectors are for bi-amplification. That is, using a separate amplifier for the high frequencies and the low frequencies. You would remove the flat connector to separate the internal speakers for that purpose.
A manual for the tsi series can be found at retrevo.com. Register and download it for free.
http://www.retrevo.com/support/Polk-Audio-TSI500-Speakers-manual
My $.02 - don't bother bi-amping them.
Jan 26, 2010 | Polk Audio TSi500 Main / Stereo Speaker
1600 nokia phone insert sim problem
At the bottom of the phone you have the headset, charging and easy flash (USB) connectors. If the easy flash (USB) connector is soiled, oxidized, dirty or the terminals are shorted; it can cause the sim card issue. The unit starts and takes long to display then "insert sim card" appears.
To resolve the issue:
  1. Clean the easy flash connector with a lacquer thinner or even a 70% ethyl alcohol.
  2. Make sure dirt is removed between the terminals.
  3. If you can disassemble the unit, clean the connectors terminals from inside.
  4. Clean also the board.
To disassemble the unit:
  1. Remove A and B-covers.
  2. Remove the six T6 screws.
  3. Pry the board including the LCD frame and light guide assembly from the sides to remove it from the D-cover.
  4. Reassemble in reverse order.
Nov 03, 2009 | Nokia 1600 Cellular Phone
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus Camedia C-3030 Zoom Digital Camera Logo
46 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
