Question about Acer Aspire 9300 Notebook
Elock managment The Acer "elock" management icon is inactive. My external hard drive and memory sticks cannot be found. My internal memory "drive D" is also invisible.
  • 2 more comments
  • zrp2007 Aug 25, 2008
    please help
  • zrp2007 Sep 25, 2008
    The Version is 2.5.3006
  • Ekse May 11, 2010
    Hey,
    can you tell me which version of elock management is installed in the laptop
    Thanks,
    Ekse
  • Ekse May 11, 2010
    which version of elock management you got?
  • Acer Master
  • 13,433 Answers
Can you tell me which version of elock management is installed in the laptop
Posted on Sep 06, 2008
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Hello! I live in Norway an have a problem with my computer - it says that acer e-lock i activated and i cannot use my dvd/cd station. I am not very good in computer "thing" so you have to explain very...
The Acer Elock is used to protect your computer from any external device or access like flash drive, any external media device, optical disc DVD etc.
To make the DVD CD station active you need to go to acer elock interface and enter the password which you first entered on the computer while doing acer elock system.
http://acer-elock-management.software.informer.com/screenshot/54477/
This link can help you as it has a step by step method and screenshots also.
The only disadvantage of this Acer Elock system is if you forgot the password you need to go to Acer Custoer Center and get it fixed
Please check if the above things will help you and let me know.
Regards
Nov 26, 2009 | Computers & Internet
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Acer e lock
Yeah, I was having the same problem. Emulated optical drives are locked too. So I just went ahead to add remove programs and removed Acer Elock Management. It's useless anyways, never used it in my life. My Drives work fine now! So to everyone having this problem: REMOVE ACER ELOCK MANAGEMENT and your drives will get unlocked!
I hope it wld solve...If not buzz me........ Thanks.
Jan 07, 2009 | Computers & Internet
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
ELock password reset
one thing you can try first, is to disable the elock service from
start -> run -> type in services.msc
look for elock service right click properties startup type disabled and stop the service, on some elocks this is enought to stop it from working. but it debends I can fix this and I have done it many times now..
Dec 02, 2008 | Acer Aspire 5100 Notebook
Acer elock
You don't need to pay acer the 100usd to get the password removed,
Nov 29, 2008 | Computers & Internet
Acer e lock activated??????????????
I have a working workaround solution to this problem - save yourself 100usd (what acer requests from the unlocking) and press the ask me button to send me the free(FREE POST TO FORUM) request, Il give you the workaround, will take less than 10 minutes to solve the problem, really not worth it to pay 100usd for something this silly.
Il possibly soon make a video tutorial on how its done but for now, send me a request and il tell you how to get rid of the problem.
Jan 05, 2008 | Computers & Internet
Acer Aspire 9300 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
