Question about Panasonic DP-1810F Laser Printer
Toner order #
I have a Workio 1810F and need toner. What is the order # for the toner and where can I purchase it?
  • 284 Answers
The part you would like is DQ-TU10C -- Toner Waste Container included
if your in canada i can refer you to a number
Posted on Oct 01, 2008
Panasonis u13 code
Add Toner 1. Toner Bottle is incorrectly installed.
2. Low Toner.
3. Toner Sensor is disconnected.
4. Toner Sensor is defective.
5. SPC PCB connector is disconnected.
6. SPC PCB is defective.
Mar 17, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Pls tell me the life time of the developer powder and do I have to use only original toner
Hi, I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine. As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
Hi Its says our toner is low on the workio 1820 photocoper.
low toner means you should refill toner in the catridge, if it has be refill it will stop.
Feb 07, 2011 | Panasonic Workio DP-1820E Copier
U13 toner empty how to reset
u13 means toner is finished. replace toner cartridge
Jan 26, 2010 | Panasonic Workio DP-1820E Copier
How to refill panasonic printer 8016 toner
i dont how to fill toner in panasonic workio 8016 model
Dec 18, 2009 | Panasonic WORKiO DP-8016 Printer
My printer says the Waste Toner Box is Full? How
please don't think i'm trying to be a smartass but you need to find the waqste toner box and empty it. check your user guide.
Aug 10, 2009 | Panasonic Workio DP-2310 All-In-One Laser...
How to change the drum in a Panasonic DP-1810F Copier / printer
this is a technician job as parameters need to be configured after the replacement. if you can source the drum thats already a saving.
Jul 07, 2009 | Panasonic DP-1810F Laser Printer
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
Waste toner box
you need to talk to a dealer so they can go into service mode and reset the counters., im sorry to say i dont know what password they used to block the service mode. or i could help
Jun 23, 2008 | Panasonic DP-1810F Laser Printer
Panasonic DP-1810F Laser Printer Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
