Question about Sport & Outdoor - Others
White Outdoor Lawn Tractor 2150
Dear Sir:
My White Lawn Tractor 2150 panel displays a red discharge light anytime a load is applied (headlights,PTO, etc) It has recently had a tuneup and runs like a champ!
Could it be the alternator? And where is it located? Also ratcheting the ignition switch seems to bring off the light temporarily.
Please respond to duane090@centurytel.net
Thanks
I have no voltage to my stater with key turned, is the green wire out of switch go to a seperate solenoid?
Posted on Apr 30, 2010
    New Friend:
  • 182 Answers
It sound as if there may be a short near the ignition switch.
Posted on Aug 26, 2008
Cub cadet 1045 blades go on and off
,I take it you have an electric PTO clutch.
Cub came out with a child protect back-up blade shut down.
If you have the 3 position key with a red led that lights up when turned on then you have it .
the switch is shorting that is attached to the reverse linkage at the transmission since the system works off of ground this could be the prob.
the only other cause is a bad connection at the pto or a bad ignition switch which is part of the child shutdown.
Sep 26, 2014 | Cub Cadet Street Sign- tractor lawn riding...
After running for a while my Troy Bilt RZT tractor Colt ZT42 PTO stops working
pto going out or stater going out run till it does then replace i the red neck saya it the pto replace if you cant live with it till burns out
Aug 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
When hooking up the cen-tech 60581 charger/starter the charge status light flips back and forth from green to red while the ammeter also flips back and forth. Is that what it is supposed to do until fully...
I don't think so, It did that on one of my lawn tractor batteries but not on the other lawn tractor or car battery, I suspect something is wrong with the battery.
Oct 01, 2013 | CEN-TECH Heavy Duty 6/12 Volt Battery...
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Aug 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
CUB CADET LT 1046 WONT CRANK
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Pto switch engages, pto light activates, no power to electric clutch?
I would check to see if the clutch is acutally OK. Start by unhooking the connector at the deck and supply a 12volt source (has tro bee high amp) to the leads...Be aware! The red(or white or green) is the positive and the black is the negative....don't hook them up wrong. If you've done this and the clutch still won't turn on the blades. then you have to replace the clutch.
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Sport & Outdoor - Others Logo
348 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
