Question about Ricoh Aficio CL3500N Laser Printer
SC 486 error
Sc error consulte a su tecnico
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
If you want technical support of Ricoh, you can contact us on RICOH Printer Support 1-866-877-0191. We are always available with technical experts for your help.
Posted on Aug 09, 2017
  • Ricoh Master
  • 4,338 Answers
I have a Th-50PC77U that doesn't turn on. Relays will click and start to power up but then it goes into safe mode and the power LED blinks 7 times. Is there a circuit board i can replace to fix this?
& blinks is sc or,sd or ,su board or all 3. Disconnect the ac cord. remove the back cover. on the left are 2 thin boards with flat cables that connect to the panel. these 2 boards are the SD and SU boards. They are connected to a board to the right. This the SC board or Y sustain board. Disconnect the 2 wie plug that connects this SC board to the power board in the middle. Examine the sqauare ics on the SC and SU boards on the rt side. Look for a pit or burn mark on one of the ics. If you see one then this board is bad. Disconnect this board from the SC board remove connectors on the rt and also remove the all the screws on this board. It should now be hanging free only by the flat cables on the rt. reconnect the 2 wire cable from the SC board to the power board. Plug in the set and power on. If set turns on the that board needs replaced. You will see 1/2 of picture. If still won,t turn on then disconnect the ac cord and the 2 wire conn from power board to SC board. disconnect the other board on the left letting it hang free. re connect SC to power board,plug ac cord in and turn on. If set now will turn on then Replace that board. If stiil won/t turn replace the SC board.
Sep 08, 2011 | Panasonic TH-50PX77U 50 in. Plasma HDTV
Tip
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
on Apr 12, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Jan 18, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
May 14, 2010 | Panasonic Televison & Video
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Getting error code sc 486
Sometimes it seems to be that the sensor for the waste toner is picking up that it is full. If you clear the are that the the laser reads, many times this error code goes away. Also,, just replacing the waste toner cartridge fixes it.
Apr 03, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
2,844 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
