Question about Goodman CKL60AR60 Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
My AC is working fine, almost. The AC Unit starts up, all is well but after about an hour or so the Outside condensor fan stops running. It is still cooling just fine. I checked the capacitor, and they appear to be fine.
Historically, I have had the capacitors replaced once, and one the wires on the connector panel has burnt of 3 times. It is about 4 years old.
  • Norepose Aug 25, 2008
    Thanks for the quick reply.
    Rotation is fine - air is coming out the top fine when the fan is running.
    Bad bearings = replace the motor?
  • jb_007 May 23, 2009
    My Goodman CKL60-1 doen not come on. The circuit breaker at the panel is on
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Posted on Aug 25, 2008
2 Suggested Answers
relaga58
  • 158 Answers
SOURCE: Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
Posted on May 28, 2009
Goodman aepf426016aa
Communication problem. You say condenser stat and power are fine? if that means the condenser runs but the air handler doesn't that means the communication is good and the blower is not running. That may be a capacitor (you must have ammeter capable of checking microfarads) if not that check power it may be board driven. If no power to blower the board is bad assuming power is at board. If that is ok the blower motor is bad.
Nov 29, 2013 | Goodman Heating & Cooling
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
Outside unit doesnt start inside unit is working
This model of Goodman A/C the condenser coil get extremely dirty and what happens is when your condenser runs for a long period of time it pops the capacitor. This is the starting component for the compressor and the fan outside. the coil needs to be cleaned with a non acid condenser cleaner. Open up the side compartment of A/C look at the silver cylinder thats the capacitor if is looks swelled replace it.
May 11, 2011 | Goodman CKL30AR30 Air Conditioner
No AC
Turn off power, if this is a complete outdoor unit, remove the blower door Turn Unit back on see if the blower motor is working. If belt driven belt is loose or off, if direct drive and the fan is not working, its possible the capacitor is bad or fan is bad.
If fan is operating, then either a damper is closed, something is obstructing the duct or it is at to low
of speed.
Jul 02, 2010 | Goodman GPC1342H21A Air Conditioner
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
HI I have a 30k BTU armstrong unit, compressor runs fine , but condenser fan doesn's start, does it works with the capacitor?
Many outside AC units have just one capacitor that starts the compressor and the fan. Some units however have two. Just follow the wires from the motor to the capacitor, pull it and test it. Make sure you disconnect the power from the unit by pulling the fuse block first. If the capacitor is good the motor may have siezed up or burned out.
Dec 17, 2008 | Goodman CKL36AR36 Air Conditioner
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
976 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
