Question about Casio LK30 Note Lighted Keyboard
Casio 1600 sustain pedal problem
I have just bought a used 1600 and found that the sustain pedal (not a Casio one) works in reverse - pedal up to get sustain and pedal down to stop it.
Could reversing the wires in the audio jack, center to shield and shield to cemter make it work correctly?
Grateful for any advice.
  • daaq Sep 04, 2008
    Just found out it wasn't a sustain pedal but a volume one!
    So no problem now.
  • 4 Answers
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Posted on Aug 15, 2009
My keyboard sustain now has reversed polarity on random occasions...have tried everything, and it's not my pedal because the same things happen with different pedals.
I would suspect the sustain pedal jack on the keyboard is either dirty or defective. Try using some contact cleaner first, and if that doesn't work replace the jack.
Apr 29, 2016 | M-Audio Music
My sustain pedal works in reverse
You bought the wrong model - e.g. Yamaha models work reverse.
Return for Exchange
Or try opening up and re-solder the cable to the micro switch if possible
Jan 31, 2014 | Casio Wk-200 Wk200 76-key Digital Personal...
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
How do you make the sustain pedal work correctly? It now works in reverse and none of the pedal options will correct the problem.
If you are not using the original pedal it means that your pedal is wired backwards. You can try disassembling the pedal or the plug on the cord and reversing the wiring of the connections to see if that helps. Example if the shield of the cable is wired to the shaft of the plug, try disconnecting the wiring to the shaft and tip and wire the shield to tip etc.
Jun 21, 2010 | Casio 76 Key Smartmedia Keyboard
Bought a sustain foot pedal and it works the opposite to what it is supposed to...have to release the pedal for the sustain effect
Yep!!! Happens all the time and only a few synths have the option of selecting the operating mode.
NOW if you can open the pedal, USUALLY the switch has both the Normally Open and Normally Closed functions that a single wire can be moved to reverse the operation.
USUALLY you will need a soldering iron to make the change.
Nov 19, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Jul 02, 2009 | Roland Dp 2 Damper Pedal
Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Mar 12, 2009 | Yamaha Music
Music Logo
488 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
