Question about IBM Infoprint 6500 Matrix Printer
  • Anonymous Apr 22, 2009
    this has always worked on my 6400's but not on 6500 can it by changed from default?
Did you try "return" and "enter" ?
Posted on Sep 03, 2009
  • ahmadkamarol Nov 08, 2010
    hi, what about to change the shuttle phase, any control key to press to go the menu.
  • 21 Answers
Pressing the up and down arrow keys at the same time should unlock printer, take printer offline first.
Posted on Sep 16, 2008
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Oct 31, 2014 | HP LaserJet 4345mfp Printer
HP P3015 suddenly printing very slowly - about a page a minute
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Feb 09, 2011 | HP P3015 Laser Printer
How do you set the printer to print continously without loosing settings on the next page?
You need to save the settings via the operator panel.
Goto CONFIG Menu -> CONFIGURATIONS -> SAVE -> and save the current configurtion to a template, e.g. CONFIG 1.
Mar 29, 2010 | Tally T6215 Matrix Printer
How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Feb 19, 2010 | Canon LaserCLASS Fax 710 Printer
I have a HP Colour LaserJet 2600n and am trying to find out how many pages I have printed on it since I got it 3 years ago. I also get the problem that the oage is covered with a faint blanket of toner....
You can print a configuration page using the control panel of the printer, it would have the option page count in that configuration page.
To print the Configuration page from the control panel
1. Press (LEFT ARROW) or (RIGHT ARROW) to select the Reports menu.
2. Press (SELECT).
3. Press (LEFT ARROW) or (RIGHT ARROW) to select Config Report.
4. Press (SELECT) to print the Configuration Report page
Page Counts. This section lists the total number of pages printed, the number of color
pages printed, and information about paper jams.
Sep 29, 2009 | HP Office Equipment & Supplies
How do you print config sheet (mac address) from phaser 8500 pri
Here ya go.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Mar 17, 2009 | Xerox Phaser 8500/DN Printer
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
Printing on EPSON FX-880+
Nov 04, 2008 | Epson FX-880+ Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
524 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
