Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
How di remove call barring from nokia 5500d orange triangle on screen cannot remove it
How I remove ,,call barring from nokia 5000
Posted on Oct 30, 2008
    Brigadier General:
  • 7,752 Answers
You may need the phone have the phone reflash
Posted on Aug 26, 2008
Membuka kode pengaman nokia 1650
Hi:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 03, 2013 | Nokia 1650 Cell Phone
In the Y= menu, instead of a line in front of de Y1= there's a triangle with a bar. when i click on the triangle w bar it turns into a triangle, when clicked again into 2 triangles and when clicke
You executed the Transform Application and it is still loaded in memory taking over the graphing duties from the native OS. You must unload it from memory.
Press the APPS key. Scroll and find Transfrm, then press ENTER. In the new screen select 1:Uninstall and press Enter.
Go to your Y= function editor to type in up to 10 functions.
Oct 30, 2012 | Texas Instruments TI-84 Plus Calculator
I push scglage button and unlocks the lock
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx#5
Why can my electronic keypad deadbolt (BE365) be unlocked without a four digit user code when I press the "Schlage" button?This is most likely due to an installation error. When the lock is assembled on the door, two steps of the installation must be followed to insure proper operation. The deadbolt must be installed in the door edge with the bolt retracted, and the gray plastic cam on the interior mounting plate, through which the flat metal driver bar passes, must be pointed down (see below). The gray plastic cam has a triangle embossed on the end opposite the driver bar which should align with a matching triangle on the orange plastic cover plate below. These instructions are also embossed on the orange plastic plate.
Troubleshooting Image 2
If the cam is improperly aligned, the lock must be disassembled to a point where, with the bolt retracted, the cam can be turned to the correct position without moving the bolt. This will require withdrawing the flat driver bar completely from the cam before turning the cam. The driver bar will then pass through the cam at a forty-five degree angle when the lock is reassembled.
Sep 07, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
My nokia 5500d can't install games
That's the way the phone was made. Different phones has different file support.
Nov 17, 2009 | Cell Phones
Orange world icon in middle of wallpaper screen is it possible to remove it?
on the main screen open the widget bar on the left then simply drag and drop orange world on the widget bar
Aug 18, 2009 | Samsung S5600 Unlocked Cellphone with...
My nokia 5500d keeps switching itself off!!
re-load the firmware as it is unlocked. it can be done by some authorized dealers
Aug 12, 2009 | Nokia 5500 Sport Cellular Phone
Nokia 5500sport on it is booting ok going to rebootingloop itself
You try to format your phone for better use---
press--- *#7370#
or hard reset your Nokia N70 mobile phone by :
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Note: You will loose your data after formating the phone, so please make a copy of your data.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Nokia N70 Cellular Phone
Unlocking password
Hi ediriajila,
You can get your Master reset code from here.
http://www.lur.nu/nokia_mastercode/security_code.php?IMEI=358658%2F01%2F97557
P.S. If I'm helpful, plz dont forget to give FIXYA rating for me!.
Thanks
arundir
Feb 07, 2009 | Nokia 6288 Cellular Phone
Call barring
Call barring (network service) allows you to restrict the
calls that you make and receive with your phone. To
change the settings, you need the barring password from
your service provider.
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
network to set call restriction on, select Options >
Activate. To set the selected call restriction off, select
Cancel. To check whether the calls are barred, select
Check status. To change the barring password, select
Edit barrings passw.. To cancel all active call barrings,
select Cancel all barrings.
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
632 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
