Check
to see whether the laundry drum to the washer moves. If it does move,
then the user interface needs replacing. If the drum is locked and will
not move, you need to replace the central control unit on the washer.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Please read the tip below, explaining how to fix F70 and F71 problems.
The comment applies to Whirlpool built kenmore washers like the one in
question.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
question.
I have a GHW9100LW1 model washer and discoverd that if you remove the front bottom cover three screws there was a tech sheet mounted on the right hand side in plastic this sheet has all the error code explanations maybe that yours has a copy in it also.
