Question about Olympus C-3000 Zoom Digital Camera
Output to a TV
Is it possible to output to a TV?
    Master:
  • 852 Answers
Yes. While making output on a TV monitor, the LCD monitor on the camera is turned OFF. Connect the A/V cable, supplied with the camera, to the A/V output connector on the camera and the input connector on the TV. Note: the camera has an NTSC signal if purchased in North America
Posted on Sep 01, 2005
SOURCE:
Magnavox portable dvd
If there is an output on the portable TV/DVD, connect a cable from the output on the portable to the input on the flat screen. If there is nothing labeled output on the portable, this is not possible. Sorry
Apr 09, 2014 | Televison & Video
How do i connect head phones to pioneer pdp 5071pu TV
This model has no headphone out put. In the rear panel there are two monitor audio outputs which could drive headphones, but I think the volume output to a possible monitor matches the tv loudspeaker output, and may not turn off the audio separately.
Mar 09, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
No sound
Hello
First check whether sound control has been muted or not. If muted, as you know, there will be no output from the speakers. If not muted, and still no sound, there are two possibilities. The first one is of speaker, and the second one is with the audio output IC inside the circuit
Check its speaker first. you can check the speakers with the help of a multimeter, of with a torch cell. If speakers are found OK, and still there is no sound output, the audio output IC is faulty and shoul be replaced with same number . The number of the audio output IC for your tV is [TA8265K]. This IC can be located at the main board of your tV. If you have eneough knoledge and tools to do the job, you can replace it at home.
If you want anymore assistance from me, inform me by FixYa comment box. I've all the repair details about your tV with me. OK.
Dec 17, 2011 | Toshiba 36A61 36" TV
I dont get a clear sound even though the picture is clear
First of all take the Audio output from the LINE OUTPUT and connect to an external amplifier. If the sound is still not clear then it is possible that the fault is in the SIF section provided this is the sound distortion from a Tv program/cable program. If this is a DVD or DTH input then the distortion can be from these input units. So please confirm on them.
If the sound does not have distortion then the fault is in the OUTPUT of the audio amplifier in the TV, Possible the output IC or the coupling capacitor are defective.
Jan 21, 2011 | Televison & Video
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
I have a 37 WLT 68 TV, is it possible to connect
Strictly speaking, no. Your TV has both a line-level audio output, via RCA cables, and a SPDIF (digital audio output) connector (and a headphone jack). Any of these will output a low-level signal into an stereo amplifier or home theater AV receiver. The speakers would be attached to that separate amplifier unit.
Oct 16, 2009 | Televison & Video
Dear wayne,
Please locate audio input socket on your TV, Then Connect audio output of DVD recorder to this input socket. The optical output of TV goes to input of amp. Since the DVD recorder is connected to the TV and TV's out put connected to the Amp. Now the sound signals from tv and as well from DVD will be 5.1 surround from the amp.
If any case this does not solve your problem, please mail me the photo of the back side of TV's connections at my mail.
rkr847@gmail.com
ramesh22
Jun 18, 2008 | Televison & Video
Tv set won't start up
as your reg. output is 40v & you have checked every possible things responsible for it. my suggetion is that first you isolate power supply from hor.section & see if power supply output is ok. if it is ok then check for short & leakage in h/output like 1 hor.output tr. 2 diode or cap in eht winding. 3 check for print near eht transformer. 4 disconnect yoke connector & check . 5 & finally eht or flyback transformer.
Sep 29, 2007 | Philips Magnavox 27MS343S 27" TV
Olympus C-3000 Zoom Digital Camera Logo
184 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
