Question about Panasonic SV-AV10 e-wear Digital Camera
Play back and record
Can I play back material on, or record from, an external device, like a TV or monitor?
    Master:
  • 903 Answers
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
Posted on Sep 01, 2005
My Sanyo LCD 40XR10F TV does not recongnise any mp4 movies i have on my external hardrive or usb stick?? Does it matter what size usb disk/drive/how many files are stored on them for it to play them?
Before you loaded the hard drive, and USB did you run a "Check File System" through the TV? These devices in order to use the "Time Shift Function", have to have pass with "SUCCESS", displayed on the screen. If not the TV will format a 4GB FAT32 filing system for you. The reason your MP4's might not work might be due to a firmware update that no longer supports MP4. You should have been OK if you recorded the material from the TV. Items you record from the TV will not play on any other device. Using the FAT32 format only allows 4GB but, the TV allow 8GB and a external device can be FAT32 format to 8GB. 8GB is only 2 hours of viewing time. So that should give you some idea how little the amount of files can be handled.
Dec 21, 2010 | Sanyo Televison & Video
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Playback on external device.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
Play back, record from
Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
Panasonic SV-AV10 e-wear Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
