LG LP0910WNR Air Conditioner Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My unit show a error code E1 - LG LP0910WNR Air Conditioner
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Jul 07, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10844329
Points
101584
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
2 Related Answers
Anonymous
  • 11 Answers
  • Posted on Sep 13, 2009
SOURCE: samsung AQV12m e1 error code
Check the wiring. If it's okay, reset by switching the power from the outside unit off for approx. 1 minute.
Anonymous
  • 555 Answers
  • Posted on Jun 05, 2008
SOURCE: E1 error code
You can contact Haier Technical Support here to open a support case for this error.
My LG intello dishwasher LD2050SH gives me an E1 error
AE & E1 ERROR CODE - DISH WASHER
LG Electronics https://www.lg.com > support > help-library > ae-e1-er...
Nov 8, 2023 - An AE or E1 error code means you have a leak inside your dishwasher activating the float switch. Before you can start using your dishwasher ...
Missing: LD2050SH ‎' Show results with: LD2050SH
Help library: AE & E1 error code - Dishwasher
LG Electronics https://www.lg.com > Home > Support > Troubleshoot
Dec 13, 2023 - The AE or E1 error code indicates a possible leak from the unit. ... Then run an empty cycle with nothing in it to clean out the dishwasher. If ...
Missing: intello ‎ LD2050SH
LG Dishwasher - Error Code List ' LG USA Support
LG Electronics https://www.lg.com > support > help-library > lg-dish...
Jun 20, 2023 - If overfilling occurs, the flow switch will trigger an E1 error code and your dishwasher will turn off to prevent outside leakage.
What does error code E1 on a tankless water heater mean?
generic code for thermistor (temp sensor).
E1 Error Code This is an error on the thermistor. For instance, if your EcoSmart tankless water heater unit is displaying this E1 error code, it shows that you are being notified of the EcoSmart inlet thermistor that is not reading the proper temperature.Sept 22, 2021
Troubleshooting EcoSmart Tankless Water Heater Error Codes
May 19, 2022 • RVs
2answers
E1 Error code on Carrier AC model 42LUV080H.
codes should be listed on inside door panel of unit
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
ERROR E1-22
uve a problem with ur laser unit im affraid needs to be replaced
10helpful
3answers
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
