Question about Canon FS100 Flash Media Camcorder
Transferring video to DVE
My Canon FS100 takes beautiful video, but when I burn it onto a DVD it plays back in slow motion and there is no sound.
  • harry138 Dec 26, 2008
    jerky movement on cd recording transfer.
My serial number of my canon fs100 is not activated because when i put my serial number below my cam corder is not valid how we can solve thi problem
Posted on Nov 09, 2008
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Video clips
Is the RAM the same on both computers? Sounds like one has less RAM and therefore not enough processing power to run the video smoothly.
Mar 23, 2010 | Canon PowerShot A620 Digital Camera
Our Canon video camera will record in both HD and SD. We've recorded all of our video in SD so far and I burned some of it onto the Canon DW 100 burner and I can't get it to play on my DVD player. please...
You should burn your videos to a video format that should be compatible with your DVD player to get play. Some video formats will not be able to play to a certain DVD if the DVD player does not support it. You should burn your videos to VCD format to avoid problem because almost DVD nowadays have backward compatibility for all VCD movies. Hope this could help you..Please don't forget to rate me..:-) Thanks..
Nov 04, 2009 | Canon DW 100 DVD-RW Burner
Created a DVD from my FS100, unable to get sound when playing it on my home DVD player however have sound on Laptop using WinDVD. Do I need to change format of DVD and if so to what file type ? thanks much
It's the format of the movie clip (.mod). The files need to be converted to .mpg in order to get your sound working with WMC or other video player. Google for a .mod file converter and you'll find several out there.
Oct 07, 2009 | Canon FS100 Flash Media Camcorder
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
DOWNLOAD VIDEO FROM CAMERA TO LAPTOP
http://onlinevideodownloader.net/save-canon-fs100-video-on-ipod.html
I believe this post will offer you an excellent answer.
hope it can help you more or less!
Apr 07, 2009 | Canon FS100 Flash Media Camcorder
I was not prompted to finalize disk after copying from hard drive to DVD...
If your DVD Player is playing burned DVD, then its OK. Before erasing dvd data from your PC, confirmation of DVD Disc on another dvd player would be fine.
Regards,
Aug 25, 2008 | Sony Video Cameras
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Relisys dve-r6
Hi You haven't included alot of details, but if you are connected through a VCR, then the copy protection on the DVD will cause that effect, or if you have accidentally connected your yellow video cable to one of the component video jacks on the back of the DVD player, or possibly you are trying to play a PAL DVD on an NTSC player. Those are the most common things we see when the average consumer has video problems, but sound is ok. Hope it's one of these, and not truly a video problem. Good Luck!
Aug 13, 2006 | Sampo DVE-R3 / MX-RS200 DVD Recorder
Canon FS100 Flash Media Camcorder Logo
216 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
