Question about Dell PowerEdge 1650 Server
Why won't my poweredge 1650 boot from the cd
My poweredge 1650 will not boot from the cd I inserted and changed the boot sequence already. Trying to install windows server 2003.
  • Anonymous Sep 10, 2008
    I even swapped out the CD-ROM from another 1650 to see if that was the issue, then tried another 1650 (I have three spares now) with the same results. I've tried Dell's boot CD and Windows Server 2003 and no dice. I may end up using RIS if I can't find an answer soon.
  • Yoyodyne Propulsion Systems
    Interesting problem. Especially for the anonymous user who posted on 2008-09-10.
    Neither of my 1650s have exhibited this behavior. I would try swapping the mainboards - I believe there was a factory recall back in 2004 on the boards. Not sure why, but I know we had a Dell tech come out and swap out the boards on our 1650s.
    Can you boot with a Linux kernel CD?
3 Suggested Answers
pandan22
  • 17 Answers
SOURCE: Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Posted on Jan 11, 2009
  • 32 Answers
SOURCE: A Dell PowerEdge Server will not start
This sounds like a RAM issue or a strange peripheral problem (when the driver loads it kills the system). Try running the system on only 1 stick of RAM at a time, swapping until you find a bad stick. Also, clean the contacts off with a pencil eraser before putting them in.
If this doesn't help, pull PCI cards one by one (except for the RAID card, if any - but do pull out, clean and put back in the RAID card just in case it's a contact issue) at a time until the system boots (or just try safe mode, but this won't tell you which one is a problem).
If the system still can't boot, then I'd say it's probably the motherboard.
Posted on Jan 18, 2009
What can I do to fix this problem, my gr 500 is telling me to reboot and select proper device or insert boot media in selected boot device
You need to go into your Bios or System Setup and change the boot order or boot sequence. It sounds like you might be trying to boot from a Network or Lan. It could be that you are trying to boot from the CD drive but instead of having a operating system disc in the drive you might have a movie or music cd in the drive.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Gateway 500GR PC Desktop
My Laptop is Satellite L505-S5990,After i change boot sequence from booting with CD rom to HD it won't effect changes.WHy is it this way>Any tips as to why it is so and how i can change boot...
Changing boot sequence.
Go to bios setting, click "F2" upon start up( when you read the bios and HD readout ). Choose the part boot sequence, click " enter" and choose what drive will be use first.
Save the settings upon exit.
Hope FixYa helped you out!
Aug 17, 2011 | Toshiba Satellite Laptop with Intel Core 2...
I want setup windows xp my ibm thinkpad t23 i can pot cd & restart press f12 but not start setup plz halp me haw can i setup windows xp my ibm thinkpad t23
If your trying to reinstall a new copy of Windows in your computer then first thing you need to do is change the Boot sequence of your computer so it will load the Windows CD you inserted then it will run the set up.
To change Boot sequence:
1. Go to BIOS - Press F1 or F2 (depends on model of your computer) immediately after you turn you computer on
2. Go to Boot Menu on the top of the window
3. Change your Boot priority - make sure your dvd drive is your first or primary boot.
4. Press F10 to save and exit.
Make sure you have your Windows CD inserted before pressing F10 coz your computer will restart and will loadautomatically load and run the Windows Setup
Note: If a message "Press any key to boot from CD" appear on a black screen press any key to start the set up
Your Feedback is greatly appreacited.
Hope this information will be helpful. Thank you for using FIXYA.
Apr 21, 2011 | Computers & Internet
DELL POWEREDGE 6400 IS NOT BOOTING FROM THE CD
Go to your BIOS and change the boot sequence so that the system boots to the CD 1st. (You should see a tab or label that says Boot Order or Boot Device.)
Good Luck
C2S
Aug 13, 2010 | Dell PowerEdge 6400 Server
Am trying to format my laptop but i do nt know the proceedeer and is giving me tougth time
It's easy. First make sure the laptop is set to boot from CD drive. If it doesn't ell you how to change the boot sequence on start up then you will have to enter the BIOS on boot (normally either F2 or the delete key)
Change to CD drive as first boot device.
Insert OS disc and press any key to boot from CD.
Done.
May 05, 2010 | HP Computers & Internet
Unable to boot from cd
change the boot sequence first priority to cd and next to harsddisk.....
Feb 06, 2010 | Dell PowerEdge 700 Server
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Dell poweredge 1650 and norton ghost
okay, hate to answer my own question. Where I got confused was with the protocol.ini file that is used in Norton Ghost on a boot disk to load the network information, including the network protocol to be used (netbeui in this case) and what network card was to be used. Thus the last part of the protocol.ini file is where I needed to add the missing information. I needed to add the slot = required value to identify what one of two network cards in the dell PowerEdge 1650 was to be used to connect to the ghost server (in this case, the two cards were idenified by a number such as 0x0110 and 0x0120). The strange thing is that I also noticed that there is a third network port on the back of the server, but I am not sure if it is active or not, but nothing came of as of yet. But I am now happy to report that I can connect to the ghost server to image the machine I need to image.
Edward
Nov 19, 2008 | Computers & Internet
Poweredge 1650 not booting
It is possible the mainboard/motherboard is bad. However, you might want to check the internal fans on the 1650 to make sure they are not clogged or they are not obstructed. That would be the
first thing to check. After that if nothing work, then look to reset the CMOS (you should simply be able to short a jumper for them) or just simply take out the CMOS battery for a minute, then reconnect it.
Mar 19, 2008 | Dell PowerEdge 1650 Server
Dell PowerEdge 1650 Server Logo
1,663 people viewed this question
Alun Cox
