Question about Olympus C-3000 Zoom Digital Camera
Batteries How long do the batteries last in the C-3000 Zoom?
    Master:
  • 852 Answers
You will be able to shoot approximately 300-400 frames with the LB-01 Lithium batteries, under normal use. Battery life widely varies depending on the type of battery, manufacturer, camera use conditions, etc.
Posted on Sep 01, 2005
My C-3000 indicates that the batteries are dead even if I put new batteries in the camera.
It is possible that there is a fault, or that the battery connections in the camera are dirty or corroded, but digital cameras are famously demanding on batteries. You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc or "long life" batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
Oct 29, 2010 | Olympus C-3000 Zoom Digital Camera
My fe 230 battery doesn't last long
Unfortunately, all digital cameras with zoom and flash eat up batteries pretty fast. The best thing you can do is buy backup batteries, and have them when you have some serious shooting to do. Also, rechargeable batteries don't last forever, and start losing energy after awhile. You can order batteries at a great price by shopping on ebay. Good luck!
Mar 14, 2010 | Olympus FE-230 Digital Camera
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
My C-3000 is not opening the lens...the top screen is flashing 81 (the number of pics available on the card) the front screen is blank...I've changed the batteries and flipped through the power mode dial a...
If the camera hasn't recently been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 13, 2009 | Olympus C-3000 Zoom Digital Camera
Batteries lose charge quickly
Some batteries take a long time to properly charge and only last about three hours, I would try the quick charge batteries from energizer...some batteries aren't meant for high tech devices.
Jun 03, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Batteries
The Olympus Ni-MH batteries will provide approximately 200 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are also rechargeable.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Batteries
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Batteries
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Batteries
With the provided Olympus CR-V3 batteries, you will get approximately 300 images under normal use. Using the Olympus Ni-MH batteries, you can get approximately 120 images per charge, and with alkaline batteries you would get approximately 30 images.
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Olympus C-3000 Zoom Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
