Question about Kenmore 53642 / 53644 Side by Side Refrigerator
ICE MAKER ON KENMORES ELITE SS
MY ICE MAKER IS NOT PRODUCING ICE HAS NEW FILTER WATER SUPPLY IS GOOD.
THERE IS A RED LIGHT BY ON / OFF SWITCH FOR ICE MAKER THAT IS BLINKING
  • 639 Answers
Friend,
ngfam1 At your service!
You need service this time !
Sounds like a Thermostat problem!
How old is the ice maker?
If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have a Kenmore Elite refrigertor. The ice
hi,please remove ice maker see if an ice is jamming it up first...second on the freezer ,when you open it up...is there a switch on the wall..that is a infrared for the icemaker,,if so switch it off...remove ice maker...check it first....if its ok...possible problem with sensor...check these things,,,is filter ok...is water coming out of door,dispenser...then filter ok....good luck call if need assistance,,,michael,,doctor airr appl.repair..843-384-8474...
Mar 28, 2010 | Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker
Friend,
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Friend,
There are a number of causes for this situation!
I would need be hands on to remedy this!
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 25, 2008 | Kenmore 53642 / 53644 Side by Side...
My trio is producing pink ice, the sears guy came and told me that it is the water, but no where in the house has pink water. it happens periodically, I changed teh filter, but no luck, any ideas
It is not a conspiracy. Utilities are strictly regulated, they are not trying to kill you, and they are not putting strange chemicals in the water to mask other things. Utilities deal with taste and odor problems by producing cleaner water, not by adding things to mask the issue.
The pink ice is from the lines feeding your ice-maker. I am surprised the repairman never heard of it. I would call a better company next time. This issue is very common with new ice-makers, or new lines. To clean the lines you can run massive amounts of tap water through it, or a couple bottles of carbonated water. This should clean it out and you will no longer have pink ice.
Also keep in mind that ice refracts light, and depending on the lighting in your house and the type of ice you are looking at, it can appear blue, red, green or any other color, when it is actually not. If you are not sure - take it out in the sun and look at it there - where the light is more "white". Also, water concentrates solutes when it freezes, so any discoloration coming from your water softener may be more noticeable in your ice than in your tap water.
However, this is far more likely just the common problem that happens with new lines. Occam's Razor - look it up.
Mar 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
175 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
