Question about HP Photosmart C4280 Aio Printer
Printer does'nt work with non H P cartridges
I have recently replaced the original cartridges with non H P ( refilled ) cartridges.Now the printer won't print! The printer screen says - incompatible cartridge(s)-. But if I remove the colour cartridge, the printer will work. How do I make the printer work when the colour cartridge is installed. Or should I throw the H P away and buy a Cannon?
    Scholar:
  • 137 Answers
It is pretty clear that you have a defective color cartridge. Return it to your vendor for a replacement. You may have some success cleaning the contacts as shown here, but most likely you need a warranty replacement color cartridge.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Aug 25, 2008
Refilled my ink cartridges on hp 309g gets error message
Yes it does work on HP C309g-m if you place a cartridge one by one as follow:
1- open the cover
2- replace an original hp cartridge by the compatble non hp cartridge
3-unplug the printer
4- close the cover
5-plug printer back on
6- press ok to all messages
7-repeat from step 1 to 6 above for each new non hp cartridge
Et Voila.
Many Thanks
Oct 09, 2012 | HP Photosmart Premium C309g multifunction...
When tthe samsubg SF565pr printer shows non samsung error , what does it mean??
each printer cartridge has several pages lifetime. if the cartridge is empty if u refill it the printer starts showing non samsung. but u can still print. if not printing at all replace the cartridge with original one.
Aug 25, 2011 | Samsung SF-565PR/XST Printer
I have HP laserjet all in one 2840. got massage replace supplies. replace black ink. massage still there. printer does not work. please help tell me what to do thanks, Troy
Did you purchase a new cartridge or refill? These supplies have a non-resetable chip on them that must be replaced when a cartridge is refilled. If it is an new HP original cartridge, contact HP and have them replace it. If it is a refill, contact whoever you bought it from and get them to replace it.
Apr 14, 2011 | HP LaserJet 2840 All-In-One Printer
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer does not recognize new ink cartridge
Are you using "refilled" hp cartridges? If so, they may be interpreted as "empty" or a non-hp cartridge if the carrtidge shell was manufactured prior to the recent time that hp began coding the electrics on the same type cartridges. This can also happen if you are using "compatibles". If this is the case, try buying original new hp carts. If that is what you already have, return the cart to the store as defective and as for a replacement.
Apr 28, 2010 | HP Photosmart 3210 Printer
I dont know how to refill the ink of my printer please help me iP1980
How To Refill Ink In Printer Cartridges – Video Instructions
Inkjet toner refill - Beware: Non-original Toners Can Cost 31% More Than Original HP! www.HP.com/IN/Toner Stop Check Fraud Now - Prevent Check Fraud with Source Technologies MICR Printers! www.SourceTech.com This video illustrates the various steps required to refill printer cartridges at home using disposable syringe and a bottle of printer ink.
Jan 29, 2010 | Office Equipment & Supplies
HP Officejet J6480 ink level control
Your printer is the genune hp printer. It will not show the ink level of refilled and non-HP cartridges. Try the original one the problem will get rectified.
Apr 08, 2009 | Digital Products Hewlett Packard OfficeJet...
Recalibrating a refilled black ink cartridge for a photosmart 7960
your printer probably cannot recognize one of both cartridges
clean the contacts of the cartridges and the contacts of the cartridge carrier  with a wet towel
if that does nt work your ink cartridge has probably overheated  because air has left in the cartridge after refilling and must be replaced
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
Sep 09, 2008 | HP PhotoSmart 7960 InkJet Printer
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
HP Photosmart C4280 Aio Printer Logo
156 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
