Question about IBM Wheelwriter 30 Typewriter
IMB WHEELWRITER 5
THE CARRIAGE WILL NOT MOVE, IT STAYS TO LEFT. ONLY 1 BEEP OCCURS, LIGHTS AT RIGHT COME ON, LINE SPACES
  • tenecfan Aug 25, 2008
    thanks, I tried the WD40 and it still won't work. The carriage will move when the tyewriter is off. The batteries are terrible, Could this be the problem?
  • IBM Master
  • 3,594 Answers
Will the carrier move yo the rt. with power off ? Try a little WD40 on the silver shaft that runs thru the carrier. Look for foreign objects and debris inside the t/w.
DickyO
Posted on Aug 25, 2008
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Jul 01, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
112 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
