Question about Toshiba 2060 Copier
Wrench symbol on Toshiba 2060
What does this mean? copier was purchased used and I have no book...
  • Toshiba Expert
  • 1,326 Answers
That means you have a Error code or a problem with the copier. What dose the display show as a code???
Posted on Sep 10, 2008
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
Please, I bought a used toshiba 2060 copier, if I put it on this is what showed on the screen "SLUIT ZIJKLEP BENEDEN" could you please tell me what it means. Again could you show me how to change th
OOOOH NOOOO! You wasted your money sorry to say. The 2060 is an analog that is obsolete, a good majority of the parts in that machine are unavailable. I would cut your losses.
Jan 22, 2013 | Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Add paper symbol is lit, paper is in it, but it w...
Paper tray up motor unit is available , in that unit there will be a tray up gear , it may warn out, you have to replace the gear
May 20, 2010 | Toshiba 2060 Copier
Toshiba 2060 wrench call for service error code
thats a problem with the feeder, when you guys moved the copier you may have knocked it slightly out of place, hence the error code to prevent the machine from a miss-feed and jam.
Jul 07, 2009 | Toshiba 2060 Copier
The machine shows spanners
If you press the ' clear ' and ' 8 ' button, at a time both has to be pressed continuously then after two to three seconds you can see some code like "c44", "c43", c26, "c01".
the spanner means it is call for service. you have to call a service engineer if the symbol is blinking even though you may clear some of these with the codes.
These spanner blinks then it is saying that some part has gone bad and it need the replacement , service, reset of the code. any one of the three.
Nov 18, 2008 | Toshiba 2060 Copier
Got the dreaded "Call Service" symbol
First of all what Error code is being displayed????? Need a place to start from...... It could be one or two or all threethings----- Fixxing thermal fuse, Thirmister, fuser heating lamp...
Apr 24, 2008 | Toshiba 2060 Copier
Wrench and Snowflake
wrench means service problem. "snowflake" I assume you mean the developer symbol. Machien on - depres the clear key then the expose key then the clear key again then the expose key you are now in simualtion mode. depress 20 print 01 print this will turn of the maintenance or wrench code. Depress 24 print 06 print will clear the developer. turn on and off
Apr 09, 2008 | Toshiba e-Studio120 Copier
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
