Question about Mitsubishi Televison & Video
I was just given a mitsubishi wt-46809 rear projection tv it turns on but then turns right off.
  • 7 more comments
  • chris leck Oct 15, 2008
    Ok i do not see that as a part listed for this model is it the same as the icb401 ?
  • chris leck Oct 16, 2008
    I am trying to get that chip but i am not seeing that number as the correct application for my wt-46809.
    thnaks,
    I am getting a 2-3 error code i can un plg the white wire comming from the flyback goind to the control board in front the tv will power on and stay on but the crts will not power up if i connect it back back i get the shutdown and the 2-3 error code.
    thanks
  • chris leck Oct 17, 2008
    I have already repalce the fuses and the convergance ics.The model number is wt-46809 and i already have a service manual for it and i am still stuck.
    Thanks
    I cannot see any repsonse from you.
    i musr be doing something wron i get an email saying i have to solutions but if i click on one then i cannont see the second on ? please help don want to make anyone mad...
  • chris leck Oct 18, 2008
    I have read this information before and i have the 2-3 error doe and i have already ordered an icb401 just waiting for it..I am trying to find one locally but to no avail so far.I was just trying to see if there is anything else i need to be checking so if i need to order anything else i can without having to wait that much longer.
    Thanks
    I was trying to leave a comment but hit the wrong button.
  • chris leck Oct 24, 2008
    I replace the ic and diode d5a51 which i found was out.Unfortunatly i am still getting the 2-3 error code and no power on.
    Thanks
  • Mitsubishi Master
  • 5,138 Answers
You Said that you unpluged white wire coming from flyback transfomer going to Where ? if this wire goes to your screen and focus block control, and set comes on then your screen/focus block is bad also if it goes to the high voltage spiltter block set will set down . How to tell disconnected Red lead ,high voltage lead comming from FBT,if high voltage comes up the trippler/splitter block is bad.
Posted on Oct 19, 2008
  • 4,472 Answers
First try that IC then report back. Unfortunately this is the process to fixing the tv. Once you have done that I would love to know the results. If you need assistance before or during that time please let us know. If you have a moment please accept and rate a solution you find helpful and I'm sure the expert including myself will be more then happy to assist you further if need be.
Thanks
Lee
Posted on Oct 18, 2008
    Sergeant:
  • 306 Answers
Now that you've gone this far, youcan continue with this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
If this is too much for you then call an authorized service center to repair your 2001 Model TV and have them give you an estimate.
    Sergeant:
    Champion:
  • 258 Answers
I think you screwed up
Posted on Oct 17, 2008
  • Efren Javier
    Efren Javier Oct 17, 2008
    check the settings carefully you can check the manual on the internet or the plug are loose
  • 2,326 Answers
Click here to check more troubleshooting info for your TV.
Please provide the chassis number to see if i can locate the service manual for you.
Posted on Oct 16, 2008
  • Mitsubishi Master
  • 19,396 Answers
Test the power board first.
  • Ginko
    Ginko Oct 16, 2008
    Sorry,
    23 means Horizontal Deflection failure, therefore you will have to check a number of component failures that can cause horizontal deflection failure, following the service manual/
    The most common problem is the failure of vertical output amplifier, that cost around $150 to have repaired.
  • Ginko
    Ginko Oct 16, 2008
My mitsubishi model doesnt turn on i tried the menu and input and im getting the 2 2 blinks also pictiure noy looking good blurry bottom and top
I hope our talented expert would have given you helpful info in chat session about your tv problem, let me know if you need further help.
Thanks.
Sep 26, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Televison & Video Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
