Question about Olympus Camedia C-211 Zoom Digital Camera
Type of batteries
What type of batteries does the camera require?
    Master:
  • 852 Answers
Olympus recommends the use of Nickel-Metal Hydride (Ni-MH) rechargeable batteries or Olympus CR-V3 (LB-01) long-life disposable lithium batteries. The batteries are only used to power the camera. The print engine in the C-211 Zoom is powered by a battery pack self-contained inside each Polaroid® Type 500™ film pack.
Posted on Sep 01, 2005
4 Suggested Answers
neta
  • 852 Answers
SOURCE: Type of batteries
You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
Posted on Aug 31, 2005
neta
  • 852 Answers
SOURCE: Batteries type
Four AA-size alkaline batteries, lithium batteries, and Nickel-Metal Hydride (Ni-MH) batteries can be used. The D-460/490 Zoom can also use two Olympus CR-V3 (LB-01) long-life lithium batteries. Olympus recommends the use of Ni-MH batteries or CR-V3 long-life lithium batteries (where applicable).
neta
  • 852 Answers
Defiant mini led work light
This is not actually a camera. I would expect the information you require to be in either the manual, or on the manufacturer's website
Aug 04, 2017 | Cameras
How do I recharge the battery on a Polaroid t1455 Camera?
Depending on the battery formulation, you may want to apply the proper type charger or AC adapter. More specific data in battery type would be beneficial to further answer. As lithium ion, nickel metal hydride, nickel cadmium and lead acid type batteries are all so different it would require the proper charger selection for the battery .
Jan 15, 2015 | Polaroid t1455 Digital Camera
What is it features ?
MPN Capture 1300 Key Features Resolution 1.3 Megapixel LCD Screen Size 1.5 in. Digital Zoom 2x Lens Interchangeable Lens Not Interchangeable Lenses Focus Type Fixed Focus Image Quality Image Sensor Type CMOS Camera Resolution 1.3 Megapixel Image Resolutions 640 x 480 • 320 x 240 • 176 x 144 Exposure Control Aperture Range f3 (w) Storage Memory Type CompactFlash Card Type I Built-in Memory Size 8 MB Compression Modes Fine • SuperFine • Normal Compression Type JPEG Flash Flash Type Built-In Flash Functions Flash Off • Auto Flash • Fill-in Flash Viewfinder / Display Viewfinder Optical LCD Screen With LCD Screen LCD Protected Position Without LCD Protected Position Interfaces Interface Type USB Power Supply Battery Type 4 x AA Batteries Included Features Built-in MP3 Player Unknown Built-in Microphone Without Built-in Microphone Built-in Speaker Without Built-in Speaker Tripod Mount With Tripod Mount System Requirements Operating System Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows ME • Microsoft Windows NT • Microsoft Windows XP Warranty Warranty 1 Year Miscellaneous Included Accessories 4 x AA Batteries • Software • USB Cable • Hand Strap UPC 647499779101
Mar 22, 2011 | Veo Capture 1300 Digital Camera
Why is my camera batteris won't last what type of
You didn't mention whether you're using rechargeable batteries or throw-aways. If rechargeable, I recommend Ni-MH over other battery types. They hold a good charge, and can be recharged about 300 times. Your short battery life may also be due to corrosion on the battery contacts inside the camera which can prevent full power from flowing to or from the batteries. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Kodak EasyShare C743 Digital Camera
I changed the battery type now it keeps turning off
First, make sure that the new battery type is compatible with your camera -- not all types will work with all cameras. If you have the correct batteries and they are fully charged, your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time.
Oct 13, 2009 | Cameras
Batteries do not last long at all
You didn't specify a camera model or battery type, so the response has to be general. If you're using rechargeable batteries, make sure that they are the type specified in your camera's manual. If the camera requires Ni-MH batteries and you've been using Ni-Cd, the batteries will run down quickly. Also, if using "standard" (non-chargeable) alkaline batteries, make sure that they are fresh, premium batteries, not store brand batteries.
I hope this solves the problem -- if not, please post again with camera model and the type of battery that you've been using.
Aug 23, 2009 | Kodak Cameras
I'd like to know if there's a specific type of battery that needs to be used for this camera
Sony DSC-S700 camera requires 2 rechargeable batteries and related charger.
Click HERE to see battery pack and price.
Mar 26, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Kodak C763 - fully charged battery - blue lights go and blink for a few seconds - camera will not turn on, lens does not open.
Hi-
When you say 'fully charged', is it the original battery from the camera, or another type of battery?
The description you give indicates one of three possible issues:
1. Your old battery can no longer hold a sufficient charge and though it can give enough to show activity (blue light), it may not hold enough to run the device. You may need to replace it > should be available at most retailers that sell Kodak cameras.
2. Wrong type of battery used. Check to see what type of battery the camera requires: NiCad, Lithium, etc. are all different, and not all can be used in these cameras. It's not just about the battery size.
3. Did you drop it? If so, the threads for the lense may have been damaged, not allwing it to eject from the body.
Since you bought a Kodak, you are lucky. If options 1 or 2 do not fix the problem, contact Kodak and they will usually take care of you.
DigiChick
May 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras lens stuck out and wont turn on
eject the camera battery and clean with pin your battery tip in your camera after that turn on your camera .
hope its helpful for you
Oct 16, 2007 | Samsung Digimax S630 Digital Camera
Olympus Camedia C-211 Zoom Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
