Question about Zebra 105Se Thermal Printer
Cancel Job One of my EE's accidently printed about 5K labels and I need to cancel the job but I have tried and it doesn't work, it keeps printing and I cant stop it! Can anyone point me in the right direction on how to cancel a job on a Zebra Model 105Se?
  • Zebra Master
  • 2,794 Answers
Turn the power switch off. Exit the label program on your computer.
Turn the power switch back on and restart the software.
The reset button wont work because the job is spooled in the computer. Sometime you can cancel it from the computer if you have access to the spooler.
Posted on Aug 25, 2008
How to cancel labels
Aaron:
When multiple tags are waiting to print, to cancel should press the CANCEL button for more than five seconds. Also cancel print job in Windows spool. Roberto Martinez Mexico padrino99@prodigy.net.mx
May 31, 2011 | Zebra Z4Mplus Label Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
command on the printer
loadTOCNode(2, 'resolution');
The most obvious way to cancel a print job is to find a cancel button or a
cancel menu command on the printer and to press it. So, if you have not already
done this, try this method first.
If this method worked for you, you are
finished with this article. However, you may want to read the "Prevention tips"
section to avoid this problem in the future.
If your printer does not
have these items or if this method did not work for you, try Method B.
Method B: Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this
cancels the print job.
If this method worked for you, you are finished
with this article. However, you may want to read the "Prevention tips" section
If this method did not work for you,
turn your printer off, and then try Method C.
Method C: Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel
printing.
But what exactly are you trying to do? Are you trying to cancel
printing only a single document, or are there other print jobs that you want to
cancel? And are all the print job yours, or are there print jobs that other
people have sent to the printer? If you have to cancel documents that other
people have sent to the printer, you must have Computer Administrator status or
you must have permission to cancel the print jobs. If you are using your own
printer, you most likely have Computer Administrator status. If you are printing
to a shared printer, you might have to ask the system administrator to cancel
the print job for you.
To cancel one or more print jobs, follow these
steps.
  1. Click Start, and then click Run.
  2. In the Open box, type control printers, and then click OK.
  3. Right-click the icon for your printer, and then click Open.
    • To cancel individual print jobs, right-click the print job that you want to
      cancel, and then click Cancel.
    • To cancel all print jobs, click Cancel All
      Documents on the Printer menu.
Note If you cancel a print job that you did want to
print, make sure that you send the print job to the printer again.
If
this method worked for you, you are finished with this article. However, you may
want to read the "Prevention tips" section to avoid this problem in the
future.
If this method did not work for you, make sure that your printer
is turned off, and then try Method D.
Method D: Stop the print spooler and delete all spooled
files
If you tried Methods A through C and you were not successful, Method D should
work for you. If you came to Method D immediately only to delete a print job,
some of what we say here might not apply to you, so please bear with
us.
Method D is somewhat more complex and will require a bit more work
than the other methods, but don't worry. Method D looks much more difficult than
it really is.
First, in case that you don't know how printing works, here
is a short explanation. Print jobs are sent to the printer as spooled files.
This means that the files are put in a temporary location so that the printer
can access a print queue and print jobs at its own speed. If you stop the
spooler and its files, most of the time, you both cancel printing and delete the
print job.
Note To use this method, you must have Computer
Administrator status. If you are using your own printer, you most likely have
Computer Administrator status. If you are printing to a shared printer, you
might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
loadTOCNode(3, 'resolution');
To stop the print spooler and its files, we will have you create and run a
script file that will automatically stop the service. This sounds difficult, but
it really isn't. Just follow these steps carefully.
  2. In the Open box, type notepad, and then click OK.
    Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
  1. Carefully select (highlight) all the following text:
    net stop spooler
    del
    %systemroot%\system32\spool\printers\*.shd
    del
    %systemroot%\system32\spool\printers\*.spl
    net start spooler
  2. Right-click the text that you selected, and then click Copy.
  3. In Notepad, right-click in the blank document, and then click Paste.
  4. Carefully select (highlight) all the following text:
    C:\DeletePrintJobs.cmd
  5. Right-click the text that you selected, and then click Copy.
  6. In Notepad, click Save As on the
    File menu.
  7. In the File Name box, right-click, and
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it,
you will copy and paste the name of the command script file in the Run box.
  3. Click Start, and then click Run.
  4. In the Open box, right-click, and then
    click Paste.
  5. Click OK.
  6. Notice that the Command Prompt window opens to run the command script
    file that you created. Notice also that this window closes automatically when
    the command script file has finished running. If you do not see the Command
    Prompt window open, check that you saved the command script file by using the
    correct name and that you entered the correct command script file name in the
    Run box.
Note If this method does
not work the first time, or if you cannot print anything after you use this
method, restart your computer, and then try again.
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
Print job cancel wont work
Hi, if the print job doesn't get deleted after a restart of your computer, do the following:
Click on start -> Run, then enter: services.msc Click OK to open the Services windows. Locate the entry "Print Spooler" in the Services list. Click it and choose "Stop" and "Restart". Your print job should then be deleted.
If my answer was helpful to you, please leave a positive feedback.
Jul 18, 2010 | HP PSC 1350 All-In-One Thermal Printer
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
Feb 24, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
How do I cancel a print job?
just turn the printer off...and delete the commands from the error and job folder...you have to insist ...and try to open it from control panel or Hp in all programs .if it doesn't work from tray system ...this is the way to annul the commands...if it does not want to ..restart and try it again until it get rid of it ...restarting will make it not see that is used by another device ..
Nov 11, 2009 | HP DeskJet 895cse InkJet Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Zebra 105Se Thermal Printer Logo
457 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
kenneth njonjo
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
