Question about Sony STR-DE197 Receiver
Sherwood rv 6030 surround sound, loud pop and shuts off
Receiver may play for hours, then a loud pop and shuts off, tried changing cables, checked speaker wires etc. any ideas
  • desertfounta Oct 11, 2008
    RCA Receiver RT 2600
    my RCA RT2600 will make a popping sound then shut off. It says "overload". When I unplug the speakers it still shuts off, but there is no loud sound. It shuts off in the VCR or AUX mode, not the radio or dvd mode.
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
sree-here
  • 61 Answers
SOURCE: Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Posted on Mar 11, 2009
  • 63 Answers
SOURCE: Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Posted on Mar 16, 2009
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
smarthome2
  • 1114 Answers
SOURCE: fuse keeps blowing on my Sherwood RV-5050R
Disconnect all speakers at the receiver, then replace the fuse and check power again. If your lucky, it will be ok. More than likely though, the power transformer and capacitors have been shorted by a voltage spike or drop. If you don't have a good line conditioning surge like a Panamax, APC, or Furman, get one! it will save you $$$ and aggravation in the long run. Hope this helps.
Posted on Sep 26, 2009
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Jul 11, 2010 | Sherwood RX-5502 Receiver
Memory troubleshooting on sherwood RV 5080 R
Hi Francois,
i own the same receiver with the same problem, but solved it according the following (german language) instuction with photos:
http://ekkart.de/rauhesitten/?p=198
I changed the broken capacitor against a gold cap.
regards, Bernd
Aug 24, 2009 | Sherwood AVR-525 Receiver
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Need help hooking up surround sound with my Sherwood DAS
Sherwood's site has a manual for the model RV-4060 (click here to download) but not for the 4050. You might find it similar enough to help you. Otherwise you can try a Google search for generic Dolby surround connections. It's usually pretty straightforward. Connect the audio out from your source (TV, DVD player, etc.) to the receiver. Connect the surround channel speakers to the appropriate rear panel jacks. Fire up a source you know has Dolby encoding, turn on receiver's Dolby processing from the front panel, and experiment with the different modes to hear what you get. Just remember you can't break anything just by pressing buttons.
Jun 02, 2009 | Televison & Video
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Dec 25, 2008 | Sherwood R-945 Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Dont have manuel
Try this link:
http://www.sherwoodusa.com/cc_manuals.html
I didn't see the RV-5050R on the website, but you might try
the RV-4060 manual. It is the same series at least
Mike
Nov 06, 2007 | Sherwood RV-5050R Receiver
Sony STR-DE197 Receiver Logo
161 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
