Question about Datamax DMX-I-4212 Label Printer
Media setup Could you please help me setup my i-4212 to use direct thermal printing on UPS labels?
  • Datamax Master
  • 2,794 Answers
Turn the printer off.
Release the thermal print head from the platen.
Insert the stock into the printer so that the label is below the printhead and resting above the rubber roller.
Close the thermal printhead so that it is resting on top of the paper.
Some models may have a switch on the printer to switch from transfer roller or thermal. Make sure it is set for thermal.
Turn the printer on.
Load up you UPS software. If this is a first time installation and you are using software from UPS, you may have to tell it in the printer setup setting what printer you are using so that the form settings can be transferred to the printer.
Posted on Aug 25, 2008
LATELY WHEN PRINTING ON THE DATAMAX I-4212 THE LABELS MOVE TO THE SIDE EVEN THOUGH THE MEDIA GIDE IS IN PLACE.
If the media is trying to walk to the side there is too much head pressure on that side. Adjust the green knobs on top of the print head. Lessen the pressure on the side it is trying to go or add pressure to the other to balance the head pressure.
Jul 08, 2011 | Datamax I-4208 Thermal Label Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
I'm getting a "ribbon in" error when printing Direct thermal, and there is no ribbon installed. Any ideas? The error occurred when the end users changed the label roll. Labels are loaded correctly, and...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences"
Choose the "Advanced Setup" tab
Change media type to "Direct Thermal"
Be sure that "use printer settings" is NOT selected at the top left
Click OK and you should be good.
Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Oct 13, 2010 | Zebra 203DPI Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Media settings for thermal labels
The size of the labels you wont have to tell. In the control panel of the printer you will have to tell it to print thermal and that will turn the film transfer roller off.
You may have to tell it the size though in the software you are using.
Aug 28, 2008 | Datamax DMX-I-4212 Label Printer
PLEASE HELP - Labels are printing in the wrong direction
The ups site ahs a solution to your problem. You need to send a ZT command to the printer to reverse direction
The easiest way to do it is to open the printers properties and go to the advanced tab go to Printing Defaults then select Tools then tools again and a window will popup. Enter ZT and press enter. The Send button should now be enabled. Click on it. DO NOT touch anything else. Close all windows and try printing . If this is not the direction you want , rod and this time enter the ZB then enter. There are only 2 commands ZT and ZB
Good luck
Aug 22, 2008 | Zebra Eltron LP 2824 Thermal Printer
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Datamax DMX-I-4212 Label Printer Logo
145 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
