Question about Kitchen Ranges
Gas hob ignitor keeps sparking for no reason - Kitchen Ranges
  • 3 more comments
  • purrr_kitten Dec 28, 2008
    my stove keeps sparking for no reason
  • scaramellini Feb 03, 2009
    The gas ignitors of my kitchen hobs start sparking for no reason and do not stop. What can I do to fix it? and why is this happening?
  • djbammy Feb 21, 2009
    My cooker hob keeps clickin some poeple say igniting, anyway,
    Its stressfull how do i get rid of it when i turn the gas on it still click grrrrrrrrr. This is annoying. Help me!!!
  • Anonymous Mar 09, 2009
    I have the same problem and it did not start after cleaning...aka getting wet.
    All and random burners. Heard it could be that we lost the ground on the power supply?
  • sniper6 May 09, 2009
    igniters keep clicking when burners are off
I had the same problem, I removed the 4 switches from the gas knob stems, since they are connected with wires, and blew them out with an air compressor, there was water in one of them, put them back and they work fine, e-mail me at crzr74@hotmail.com with more questions as I don't get on this site often.
Frank
Posted on May 20, 2009
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
Ovens won,t function, no spark or gas but gas hobs work fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 30, 2010 | Rangemaster 110 (Gas) Kitchen Range
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
My baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Jan 31, 2010 | Baumatic 23 in. BT62 Gas Cooktop
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Problem with gas double oven
im in uk not us so don't know this particular appliance. however many gas appliances turn on the ignitors for other parts than the one required - ie if one burner on a hob is lit, the other ignitors spark as well. suspect you don't really have a fault
Apr 12, 2007 | New World Spirit 110 (Gas) Kitchen Range
Kitchen Ranges Logo
1,537 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
