Question about Sony KV-27S66 27" TV
My sony kv27s66 turn on than off after one sec
    Genius:
  • Sony Master
  • 1,550 Answers
The tv got problems on the power suply thats why going on to protection mode
Posted on Aug 25, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
I have a Sony Trinitron TV model number KV27S66. This morning I turned it on, it worked for a few seconds then the picture became a vertical rainbow and then the TV shut itself off. After unplugging i
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 14, 2014 | Sony Trinitron Stereo Kv-27s66 27 Inch...
Sony Kv27S66-I'm seeing horizontal lines through the screen the last few days. Checked the cable connection, reset the set-up, but no change. Color is still excellent on the TV, anything I can do or...
You must pull the main board out and re solder the vertical IC. This IC is mounted on a large heat sink. I remember that this vertical IC is of the TDA series. It would have seven pins. The pins will have to be re soldered, please do not use too much solder. You do not want to short the pins with excess solder. Next, you will need to check and replace the capacitors that are near and next to the vertical IC. We are talking about four capacitors, in this area. These caps, when weak, will create those horizontal lines you talk about. Second, the weak cap will cause the vertical IC to over heat and the pins will separate from their perspective grounds. Thanks for asking me, and show all hands of support!
May 06, 2011 | Sony KV-27S66 27" TV
Hey! I'm trying to turn on my Sony Trinitron KV27S66 but it flashes the standby light and doesn't show an image. What is wrong with my TV? What can I do to fix it?
Hey there,
Is it set to the correct input?
There should be a button on the set or on the remote called "input" or "source".
If you're trying to watch tv, make sure it's set to Cable, etc.
Hope this helps!
Mar 24, 2011 | Sony KV-27S66 27" TV
My Sony Trinitron stand by/timer light is on and will let me put tv on but only stays on for a few seconds . Model #KV27S66 Oct 99
Your TV has an overload due to some faulty components inside it. This type of fault is usually noted with overheating of horizontal output transistor connected to LOT of the TV. This may be due to LOT fault, or fault to the transistor itself. When it overheats, it put a short between supply rail, and the power supply regulator system inside your TV will detect that short and will shut down automaticaly. Please note; if the TV works after some time, say after 15 or 20 minutes; and again shuts down after working for a short period, and the cycle repeats, surely there is a winding short inside LOT, which cannot be detected by normal multimeter measurments. If it is so, replace LOT and the horizontal output transistor at the same time.
Oct 14, 2010 | Sony Televison & Video
My sony ericsson v630i turn on for 3 sec's then
Go to Sony authorized service center & get the Phone software checked as it might have gone faulty.
Jul 17, 2010 | Sony Ericsson V630i Cellular Phone
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KV-27S66 27" TV Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
