Toshiba Portege M400 PPM40U01000E Tablet PC Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have install win 7 on portege m400 , but pen not working! Please help me!
k24674
Level 3:
  • Toshiba Master 8,093 Answers
  • Posted on Aug 18, 2011
k24674
Toshiba Master
Level 3:
Answers
8093
Questions
0
Helped
4675345
Points
21596
Go to the Toshiba Mobile support web site for you exact model. Select Drivers download. Select Windows 7 32bits or 64 bit and download the latest versions of all that relate to the Tablet module, and that includes the Wacom driver.
If you Windows is genuine you can uninstall all the Wacom drivers then execute the Check new hardware wizard ( of Hardware changes) or even Windows Update
Pen
in what way can't you use it? does it turn on ?
1helpful
2answers
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
1helpful
My Portege M400 will not turn on with the battery installed. It will work if you remove the battery and use the power supply. The power light only blinks yellow while the battery is installed. I have tried...
You look very much the unlucky owner of a busted battery.
I'm afraid the battery will have to be replaced. Meanwhile, do not use it with the power supply; not only it will do no good, as you already determined, but it might damage the power supply itself.
How to enable the touch screen on my toshiba satelite r10
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
4helpful
3answers
2answers
I need to reformat my toshiba portege m400-s5032. the only way i can do this is if i get it to boot by cd when loading up. how do i get to this option screen?
Open your system bios setup. Then under the boot options make sure your cd drive is one of the drives enabled in the boot path. Hope this helps & please remember to rate my answer. Thanks.
Clock of the computer
This means that the cmos battery on the motherboard is flat and keeps losing time and date and probably the memory settings, this is only a small disc shaped watch type battery CR2032 and can be found on the motherboard, a pc repair shop would be able to do it for you for a small fee.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
