Question about Kenwood Car Audio & Video
Hi, the motorized front of my Kenwood KDC-9027 is playing up. It stops the headunit turning on, when i can get it on the front moves and the unit is turned back off no matter what i press. The front feels loose and doesnt shut automatically. Thanks
  • Steve Hatt Aug 31, 2008
    Thanks for the reply. Ive checked the ribbon cables and they look good. I thick ive found the problem. The front motorized panel is belt driven from a motor through a series of gears. Ive found a gear that is shredded and bent, looks like it over heated. Is there anywhere i can get a "Motor module" or gears for the kenwood KDCW9027. Thanks again
  • 29 Answers
Maybe the flexible ribbon cable between the face plate and the unit itself is broken and needs to be replaced. check partstore.com for part if you can do the repair.
Posted on Aug 26, 2008
  • Tibor Makai Aug 31, 2008
    I had a similar stereo in my Jaguar, but I never had issues with it. I had it for only three years though.
    I found a place here in US where they sell Kenwood parts, I assume that you are in UK, judging by the model number of the stereo. There is a list for your stereo(KDC-W9027), but there are so many parts, that is almost impossible to locate that yourself. I would contact them and ask them what you need.
    http://www.kenwoodparts.com/parts/search...
I just purchased a new kenwood KDC-138 head unit as well as two car speakers. The speakers were able to be installed onto my 2000 mercury cougar but the head unit gave me some troubles. The wires on my new...
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
May 16, 2011 | Kenwood KDC-138 FM / AM Receiver
My faceplate does not show display on my Kenwood kdc-mp632u. The lights work and the head unit in general plays the radio and cd's ect. now I have read somewhere that there are resistors inside so that...
I had the same problem and I resoldered the resistors on the board inside the stereo and it worked. Unscrew and remove the top cover and the CD slot. There are 10 of them located on the lower right side of the board. Good luck.
Jun 12, 2010 | Kenwood KDC-MP632U
I have a Kenwood KDC-MP235 installed now and bought a cable to run from my MP3 player into the aux input on the front of the unit but I can not get it to play or find an aux input switch anywhere on the...
hey dear, just do this if you wanna set AUX function: turn off your head unit.. when is in standby mode, press the volume knob and hold it pressed until it appears some words... then start moving on to differente options by clicking left-right of the right knob... you will find aux on-off
not sure if standby mode, or completely turned off (to turn it off just click the SRC mode a few seconds)
Sep 29, 2009 | Kenwood KDC-MP235 CD Player
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
Kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Apr 11, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Need unlock code for Kenwood model KDC-MP435u headunit
Kenwood may be able to give you the code via the serial number. You may be able to enter it with a combination of the switches. It may also have a "default code" Kenwood may want to see a bill of sale...not sure.
Oct 26, 2017 | Kenwood KDC-135 CD Player
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Kenwood kdc 7027
The home position switch from the angle of the front display is not pushed correctly. the problem is mechanical.
If you glue a little tip of plastic between the actuator and the homeposition switch, your problem is history.
In my case, a tip of a little tiewrap did it.
Feb 20, 2008 | Kenwood KDC-W7027 CD Player
Kenwood KDC-W6527 audio trubles
check all the wire connections in the back, you have a short somewhere
Nov 14, 2007 | Kenwood KDC-MP528 CD Player
Car Audio & Video Logo
55 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
