Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Trouble with one of my T5720 devices...
I have had our 2 Motorla T5720s for about a year and love them for keeping in touch with our 7 year old daughter....
Last week or so, I noticed that she wasn't responding to our call, it looks as if she recieves our call but when she response back the following happens.... push the talk button and the device red light above the screen lights up and has that sound as if your are ready to talk then the light goes away and you get a dble beep the light goes out and no transmit? the other device works find...any thoghts?
Thanks and Best Regards,
Howard
  • Motorola Master
  • 5,339 Answers
Likely it is a low battery issue. Either the rechargeable battery needs to be replaced or the charger isn't working properly. Try replacing the battery with 4 AAs (IIRC) and see if that works.
We have several Motorola radios, two of which came with the rechargeable batteries. In the past year, neither of the rechargeable radios would recharge. The batteries won't make good contact with the charger even when not in the radio. Now one works with AAs but the other lost its settings and we haven't been able to reset to contact the other radios.
(we looked into replacing the batteries. Motorola lists chargers and batteries for our older radios but not the two that came with their own chargers. The local battery store wanted ~$40 dollars to try and rebuild the units. Since the chargers are not making good contact, we decided to go with the regular batteries.)
Posted on Aug 25, 2008
BAGAIMANA CARA MENGUNAKAN MOTOROLA TALKABOUT T5720
Here is a link to the user guide for the Motorola TalkAbout T5720. I only could find it available in English. You will need to translate into Indonesian.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 17, 2012 | Motorola Talkabout T5720 (7 Channels)...
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Dec 19, 2008 | Motorola Talkabout T5720 (7 Channels)...
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
Lost the charger for T5720 cradel, need voltage specs for replacement
HI,
The charger cradle for this model is 220V.
Hope this helps
May 24, 2008 | Motorola Talkabout T5720 (7 Channels)...
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Pin out for t5720
the Plug is a 2.5 mmm the tip is mic, middle speaker, the end is gnd.
Jun 19, 2007 | Motorola Talkabout T5720 (7 Channels)...
Send data over T5720 ?
Those radios were not designed to transmit data, and has no any port for it.
Jun 18, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
137 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
