Fedders A6P09S2A Air Conditioner Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was wondering where the water goes or if it carrys any water at all. it is a window air conditionor
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Jul 06, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261594
Points
17064
On a window a/c unit, the water drips outside, so be sure the unit tilts downwards as it goes out. The water is from condensation, sometimes you will get lots, other times almost nothing, both normal, related to actual relative humidity. The water forms due to temperature, it forms exactly like water on the outside of a glass of ice water...
My kenmore air conditioner is spiting water into my room
You may need to change the filter on this and also try to just reset your air conditionor,
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
2helpful
4answers
While driving my 96 s10 2.2L to work this morning, I noticed once I got off the interstate and started through town my heater suddenly stopped blowing hot air and the engine temp gauge was running hotter...
you let the water drop in the header tank by how much?? half a gall!!! there must be a very big warter leak there some were,,,letting the water drop so far has let air into the water jaket in the engine so you need to bleed this air out from the bleed velve in one of the top water hoses,,,
your a lucky chap to get away with this one??? carry a big bottol of rad seal around with you?
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Air conditionor dos not drain
you will find it on the passenger side on the fire wall to the bottom you'll see a short hose sticking out with a soft wire push it through and be careful not to pock a whole the evaporator. if this information has been useful please let us know good luck
Top Fedders Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Aron
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
