SOURCE: Assembling new juki ddl 5500
Most of the time the rubber inserts have a slot in the edge of them to slide over the ears on the pan , slide them on all 4 corners and then put the assembly into the table , slide everything to the front of the table. the nail will go through both the rubber and the pan. Use a good quality ,oil resistant sealer , between the rear edge and the table to prevent the oil from splashing out while operating . If your corner cushion does not have the slots in them , put the pan in first nail in place rubber goes on top . Sometimes the rubber needs to be trimmed to height for a perfect head to table fit . The head should be level with the top and the rubber also for a smooth fabric flow while you are sewing. Hope this will help.
SOURCE: Juki DDL-8500
The DDL 8500. is a high quality, single needle, straight stitch, industrial machine. If it is still in a good condition and the present owner is prepared to guarantee it for at least 3 months, it is a good buy. Retail for app. $790.00 new.
Good luck
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
SOURCE: Hi I have 5 Juki DDL-8700-7 machines and I need to
So many machines you would be best at aution as one complete lot.
SOURCE: is there a simple way to slow the speed down on a
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
