Question about Elna 2007 Mechanical Sewing Machine
Elna Lock L4
The timing is out - would like to try fixing it myself. We do not really have a lot of service people available and always this happens when you are in the middle of a big project.
Look forward to any help.
Regards
Diane
2 Suggested Answers
99rannellis
  • 11160 Answers
SOURCE: Why does my Elna lock L4 thread wind around needle?
Could be a machine timing issue which a technician can repair.
Posted on Oct 07, 2016
I need an elna lock L4 foot pedal and lead
according to the website sewingpartsonline, this item will fit your machine (Im assuming you are in USA and 110Voltage)
https://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 23, 2017 | Elna Sewing Machines
Oct 07, 2016 | Elna Sewing Machines
Can I retime my Elna T34d myself
All the info on the machine can be gleaned from http://www.sewingnz.com/elna-lock-t34-t34d-overlocker-instruction-manual/ I am not too sure what you mean by retime. You are not suggesting that you want to reset the feed/ insert/ etc timings are you?
Is it a big job to replace the needle bar on a elna 744
These machines are not end user serviceable, no parts will be available to the general public. Parts do break. Have a trained service technician give you an estimate for repairs.
Cheers,
Embroidery Services
San Diego, CA
Jun 08, 2016 | Elna Sewing Machines
How do i fix a n elna su that will not stop after releasing the foot pedal
I'm guessing this is an Elna air electronic SU? If yes, then the problem is with the diagram inside the right side of the machine where your air control foot pedal tube feeds in. I havent' done this repair myself, I took mine to my favourite sewing machine technician. But if you are technically able, try joining the Yahoo Group called Elna Heirlooms, and then go through the threads there, there's been discussion on this repair before.
Dec 21, 2014 | Elna Sewing Machines
Free sewing machine manuals
I never seen a free elna sewing machine manual, try contacting elna and see if they have any
Dec 14, 2013 | Sewing Machines
The Hook Pinion Gear on my Elna Lotus ZZ is damaged. I have sourced a replacement. Im sure I can fit it myself but Is the timing of the machine something a novice can fix?
Timing is not something I've ever tacked, always been happy to pass the machine to my fav SM guy and keep him working as I love my Elnas. You may find it easier to track down a SM technician experienced with Elnas to fit this part for you. Especially as they are small compact machines and having the right tools can be very helpful. Also he'd be able to tell you if some of the other parts are also ageing and should be replaced at the same time.
If you are in the US you could visit www.whitesewingcenter.com and check out some of the information there, you will find it helpfull and he also hires tools to make some repair tasks easier.
And finally, there are some service manuals available from www.arizonaexpressionz.com - not for this model but you may be able to get some help from the Stella ones, they are the models after the Lotus. The manuals will assume that you are a trained technician though but should give you some pointers.
Good luck with your Lotus.
Apr 19, 2011 | Elna Sewing Machines
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
105 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
