Question about HP Photosmart R927 Digital Camera
Using SD HC Memory Card with HP R927 camera
Can a SD HC memory card be used in a HP Photosmart R927 digital camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
No. The R927 is limited to SD cards 2GB and smaller.
Posted on Sep 14, 2012
  • kakima Sep 14, 2012
  • 7 Answers
SOURCE: Will an SDHC card work in the HP photosmart R927?
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
Posted on Sep 01, 2010
Doodad
  • 64 Answers
SOURCE: locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
Posted on Jan 06, 2008
Inky
  • 691 Answers
SOURCE: HP photosmart D7300 series, will
Card format may be incompatible with reader or card may be too large for reader to manage. Try another card in the reader to see if it will read that one. If so you know the card is the problem not the reader.
Posted on Sep 19, 2008
  • 4090 Answers
SOURCE: My Kodak SD HC memory card won't work in my HP
HC stands for High capacity What is this cards size The printer may see it as bigger than the capacity it waqs designed to deal with
Posted on Jul 29, 2009
SOURCE: hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Posted on Aug 07, 2009
Card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 01, 2011 | HP Photosmart R927 Digital Camera
I can't store photos on my card; it says card locked with a lack symbol on the capture mode
If it uses an SD memory card, look on the side of the card for a switch. It may be in the "Protect" position. Move it to the opposite position.
If this doesn't help, the memory card probably needs to be replaced.
Jul 13, 2011 | HP Photosmart R927 Digital Camera
My hp photosmart r927 is very slow when processing a picture. what could cause this?
Several things can cause this. 1. Low battery 2. Memory card almost full 3. "cheap" memory card...too slow at writing data 4. Card hasn't been formatted in the camera for a long time. This will erase it so download any pics to your computer first.
Oct 19, 2010 | HP Photosmart R927 Digital Camera
Please recommend a memory card so I get the right one!
You can use any major brand of SD cards. The speed isn't going to affect your photography, though faster cards may download faster if you use a card reader instead of the camera.
Make sure you get SD cards, not SDHC cards. If a card is larger than 2GB then it's an SDHC card and won't work in the R927.
Aug 26, 2010 | HP Photosmart R927 Digital Camera
HP R927 says that the 4GB card i recently bought wrong format
ok ...see that into the side of the card( if its a SD) has a slide like button with 2 positions ...one of them is the unlocked one ...after that either format it into the camera if it has that feature...or just connect it to the computer and it will be found somewhere into the My computer as a removable drive ....just right click and format in Fat 32...this is the actual storage format fit for this cards..
Oct 30, 2009 | HP Photosmart R927 Digital Camera
HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Sep 12, 2009 | HP Photosmart R927 Digital Camera
I have a Photosmart R927 HP digital camera...I have had this camera for several years. I have not used in a couple of weeks. Turned on camera today and my screen reads "CARD LOCKED". I have never...
Jun 20, 2009 | HP Photosmart R927 Digital Camera
Can't format my 4 GB card
Hi! Unfortunately that camera does not support memory cards over 2GB. Get a 2 GB SD card and it will work.
Jan 16, 2009 | HP Photosmart R927 Digital Camera
HP Photosmart R927 Digital Camera Logo
106 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
