Question about GE WBSR3140DW Top Load Washer
GE WBSR3140GWW top load washer
Hi, my washer doesn't spin. I can hear the motor humming but doesn't move an inch. I opened the front panel and the LED light near the motor flashes 9 times then a pause. I keeps repeating the same thing. Is it something wrong with the motor?
  • eaglerock198 Sep 02, 2008
    Fixed the washer this weekend. The LED flashes 9 times indicated the motor is bad. I purchased a new motor from eBay and installed it. It was very easy to install. The washer is working like a charm.
I had the same problem and solved it without all the expensive recommended parts. I unplugged the cord from the outlet and listened for a "click" (motor reset) and then plugged it back in. I then raised and lowered the lid several times to break the magnet contact. turned it on and then it worked fine.
Posted on Jun 14, 2010
  • skrndc Sep 05, 2010
    Kirby14 was right! I let the machine fill with water, then unplugged the machine for a minute. I plugged it back in I raised and lowered the lid several times. I had to repeat the whole process several times, On the third time I heard several clicks. The 4th time the agitator started as soon as I lowered the lid the 6th time. Thanks so much for the tip!
  • 4 Answers
Bearing above transmission clutch need replacing..
Posted on Sep 01, 2008
  • hhart Sep 01, 2008
    Replace the bearing above this clutch ***'y...
Hey i have the same problem can you tell me whats wrong?
Posted on Aug 30, 2008
GE Top load Washer Model wwse5240g2ww fills with water and then does nothing else
This may require a technician visit, but you can check this:
Open front panel by using a putty knife to push in and release a clip at the seam where the front panel meets the washer's top. (usually about 2 inches in from each side.) Look at ( BUT DON'T TOUCH !!!!!) the motor. Just under the top plate on the motor is an electronic board which has an LED mounted on it. Anytime the washer is plugged in, the LED should be slowly flashing, about once a second. When the motor is running, it should flash twice as fast. If you get anything else, like four flashes, a pause, and four more flashes, call for service and let them know the flash code you are seeing.
Nov 18, 2011 | GE Washing Machines
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
Will not spin
The humming sound is most likely the pump running. Try this: Open the front panel by using a putty knife to push in the clips (2) at the seam where the front panel meets the washers top. With the washer in the spin cycle (you hear just the humming) pull the little hose off the left side of the outer tub, near the bottom. The washer will most likely begin to spin immedeately. If it does, this would indicate that the hose and the nipple it connects to need to be cleaned out. Gunk builds up there some times and then the air cannot escape back out, so the washer thinks it is still full of water, and thus will not spin. After cleaning those out, replace the hose with the tub empty of water. If the washer did not spin after pulling the hose, check the lid switch.
Mar 29, 2010 | GE WBSR3140DW Top Load Washer
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
Washer does not spin or agitate at all. Timer works.
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Feb 24, 2009 | General Electric WBSR3140GWW Top Load...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not wash or spin
does the drum turn at all if not more than likely the carbon brushes which is situated in your motor these must be about 1inche long
Aug 11, 2007 | GE WBVH6240F Front Load Washer
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
GE WBSR3140DW Top Load Washer Logo
328 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
