You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
If your garmin nuvi wont stop loading maps, then you need to reaet the unit to get it to work perfectly fine once again. Try to hold down the power button for about 15 seconds and the gps receiver will restart, this time it will load normally and show you your maps.
If that does not solve the problem, then you need to back up your maps then format your gps receiver from a computer then restore the software and maps back on, that should do the job for you.
Hope this helps.
You will need to load the MapSource software on your PC then load the maps into MapSource. After the maps are loaded and unlocked you can plug your GPS into your PC with the USB cable and load the maps.
